![]() | Home > Td5 > Erm - Help! Clutch gone I think |
alwoodley72 Member Since: 14 Mar 2010 Location: salisbury, wilts Posts: 729 ![]() ![]() ![]() |
Check obvious things like clutch fluid first, how does the pedal feel?
Cheers. Alex 98 300 tdi 90 project 88 200tdi project soft top 96 disco 1 jap import 79 911 sc 08 130 double cab utility |
stc 500100 master and slave ftc 5202 cylinder check for leaks and also colour of the dot 4 fluid ifs black seal are failing
Riverboy Member Since: 16 May 2016 Location: French sector, Earth Posts: 1288 ![]() ![]() |
I take it you are coming down the A7? There's a JLR Concessionaire at Valence that are very good. http://www.carbury-automobiles-valence.fr
Or give Pascal a ring at https://www.lignonautomobiles.com. 0475551414 They are Indy LR dealers just south of Valence and are very helpful. They speak perfect English too. The rest of the week is going to be sunny tell your wife ![]() |
sharkey964 Member Since: 05 Oct 2014 Location: On a muddy track Posts: 584 ![]() ![]() ![]() |
You could try these guys for your parts,they all speak English & prices are not bad either,might be quicker than post from UK.
http://www.landypoint.fr/en/ Good luck. Marc |
proloForêt Member Since: 16 Mar 2017 Location: Montereau Posts: 248 ![]() ![]() ![]() |
I too used landypoint just last week for some pieces. Kind, quick and honest. If piece not on their website, consider a telephone call. I imagine they are good for advice for service areas in France.
Léo |
130dreamer Member Since: 29 Feb 2008 Location: Romford Posts: 100 ![]() |
Thank you all for your help, it is very much appreciated.
The clutch fluid is still at the max level and is the normal pale yellow colour of DOT4, the pedal does not feel different. I am pretty convinced it is either the clutch or DMF. We will be heading down the A7 so will contact carbury and lignon first thing tomorrow to see if they can help. If not I will try landypoint. Thank you all again, thanks to you the wife is still speaking to me (which, yes is a good thing before some of you ask!) Andy |
When i replaced clutch last year at 100.000 mi in my 03 plate TD5, its was clutch cover plate that had most signs of ware i.e spring fingers in the centre i replaced DMF, clutch plate 3/4 way down to the rivets heads
