![]() | Home > Wheels & Tyres > Spare wheel mounted to back door hits panel when opened... |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
![]() Click image to enlarge If you look at the bottom left hand corner of the above photo you will see two nuts. These come loose and need to be tightened periodically. Remove the close bar from the door and pull the trim off to gain access. |
hugh_b Member Since: 15 Sep 2010 Location: Kent Posts: 75 ![]() |
many thanks! Will give it a go tomorrow
If you look carefully it's amazing how many newish Defenders have a dent in the offside panel for that very reason! Fortunately with the offset of my wheels this problem is no longer an issue as the wheel sits further away from the rear door! I can also now clean behind easily too!
![]() Treat every day as if it is your last....one day you will be right!! |
Went to tighten the two nuts this evening but have found that someone has "attempted" before and the threads were so mashed that i struggled to get the nuts off!
Anyway, i've tried to search for replacement part but not sure what i should be searching for, any ideas (it;s the little metal plate with the two threaded stubs coming out of it). Thanks Hugh |
Hugh,
The bit you are after is, BFU710200 Stud Bolt. ![]() |
Excellent, just ordered!
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8584 ![]() ![]() |
Also the Nakatanega gas strut door stay is now available in the UK!
Have a look HERE It will finally get on our website when my IT guru has time from her other duties. Brendan |
