Home > Puma (Tdci) > 2.4 "clacking"! |
Have you tried the old trick of putting a screw driver on various components and listening to the end of it? (automotive stethoscopes are cheap too) If it is a vac pump of something then that will help you pin point it.
Does it go quiet when you depress the clutch pedal? |
30th Mar 2017 4:25pm |
Pinky Member Since: 09 Jun 2016 Location: England Posts: 205 |
It doesn't do it when sat still. only when driving. No difference with clutch in or out
30th Mar 2017 5:04pm |
Ahh ok, that kind of suggests it's a problem in the drive train rather than engine related.
30th Mar 2017 5:30pm |
No, definitely in the engine somewhere, it only happens under load and at certain revs.
30th Mar 2017 5:40pm |
Output shaft main gear box
http://www.defender2.net/forum/topic46497.html |
30th Mar 2017 5:48pm |
I've got the ashcroft upgrade, fitted with new clutch in 2015.
I've got a wav file that you can just about hear it on, cant figure how to add it here but it's in my gallery. |
30th Mar 2017 6:11pm |
Ok cross that one off the list
stones in between brake disc and shield |
30th Mar 2017 6:23pm |
No, that would make a noise when moving with or with out engine. Have a listen to the wav, it's fairly obvious if you listen a couple of times and filter out the normal Defender din!
30th Mar 2017 6:30pm |
30th Mar 2017 7:05pm |
I hate to say it sounds ok i me
30th Mar 2017 7:09pm |
You wouldn't say that if you were driving it! People in the street are turning round to see what's making so much noise
30th Mar 2017 7:18pm |
trouble is my heading tuned to TD5 defenders
30th Mar 2017 7:21pm |
if you place transfer box in neutral make same sound ?
a frame ball clacking then drive off also are all prop shaft UJ ok |
30th Mar 2017 7:37pm |
Dieselhead Member Since: 21 Oct 2012 Location: Pulborough. West Sussex Posts: 552 |
Timing chain??
Must be something loose? Chris 2008 XS 110 2.4 Utility. Tonga Green 1953 Series 1 for restoration 1983 Mini Mayfair 2004 VW T5 Camper 2008 Diahatsu Sirion. Thats hers Classic Bolens Garden Tractors |
30th Mar 2017 8:28pm |
