Home > Wheels & Tyres > Spacers - yay or nay?
Page 1 of 3 123>
stephan123
Hi All,
Just fitted a smaller steering wheel to my Defender (big improvement - thoroughly recommended) and now looking at adding wheel spacers to further improve the handling.
Is it worth doing and if so what brand should i go for? in terms of fitting i imagine any decent garage will be able to do the work....
In any case the car is due for a service next month so would try and get them fitted at the same time!
Post #611898 24th Mar 2017 8:31pm
bear100
I would say yes, had them on all mine and they look great and help out tremendously with the turning circle, buy the best you can afford with plenty of metal between the wheel nut hole and the edge.
Look out here comes the offset wheel police Shocked Shocked Shocked 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #611901 24th Mar 2017 8:42pm
jst
if you can live with the turning circle and cornering you have leave it as is, thats how LR designed it after all.
If you need to improve either, fit them. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #611904 24th Mar 2017 8:47pm
JOW240725
I've fitted Terrafirma 30mm hubcentric spacers to improve turning circle and it is a vast improvement. Also prefer the stance Thumbs Up James
Instagram @suffolk_rovers
Post #611923 24th Mar 2017 9:32pm
stephan123
Hi JOW240725, any recommendations for suppliers?
Many thanks
Post #612040 25th Mar 2017 5:39pm
Disco_Mikey
Scotland 2009 Defender 110 Puma 2.4 DCPU Keswick Green
They sit beautifully on 30mm spacers, as well as the improved turning cicrcle Thumbs Up
Post #612042 25th Mar 2017 5:40pm
Laurie
Don't forget to tell your insurers.
Post #612048 25th Mar 2017 6:22pm
JOW240725
I had the spacers fitted while it was having some work done, so not sure where they got them from. However the best are probably Rakeway, or you can get the Terrafirma from John Craddocks to name one place. Flat Dog do spacers also. Insurers didn't have a problem with spacers. James
Post #612107 25th Mar 2017 9:28pm
Fat Cog
Personally never been a fan but if you are going to fit them make sure you tell your insurance company...I know some are a bit squiffy about them. Since 1973...S1, Air Portable's, Defender's, but only my Wolf TUL HS GS remains
Post #612109 25th Mar 2017 9:31pm
Stacey007
My last insurance wanted £50 ,
I chose the current one as they wanted less even a re map and inter cooler upgrade wasn't much added so bought with this in mind as maybe this years upgrade Smile
Post #612114 25th Mar 2017 9:41pm
JAY BOY
Wales
If you're on standard wheels i would as it gives the car a bit more stance.
I have a set of hubcentric ones for sale if you're interested drop me a PM
Jay
Post #612123 25th Mar 2017 10:10pm
Arierep
Portugal 1995 Defender 90 300 Tdi SW Alpine White
I use 30mm hubcentric spacers with Wolf wheels.
Was a bit hesitant to use them at first but I wanted the extra track width and to keep the Wolfs at the same time.
Did a 11.000km offroad trip in the Sahara with them, 0 problems and the track width was great with 80L of diesel on the roof rack.
My turning circle is still the same, I prefer to keep the CVs safe and sound
Post #613161 29th Mar 2017 10:11pm
proloForêt
France 2008 Defender 90 Puma 2.4 XS CSW Java Black
Crazy. In France to change the track of a vehicle with spacers is illegal. To change the track with oem wheels with different offset is not illegal, if these oem wheels were technically available from factory for the vehicle at some point during production.
Post #613172 29th Mar 2017 10:42pm
camelman
Other option is different wheels with larger offset.
Also means less weight than original wheel + spacer.
You can buy a set of modular wheels with ET0 offset (33mm further out than standard) for the same price as a set of spacers.
Post #613220 30th Mar 2017 9:26am
proloForêt
Can I ask you what is meaning the term "modular wheels" in this instance?
I am interested in this concept.
Post #613226 30th Mar 2017 9:56am
Page 1 of 3 123>
