![]() | Home > Td5 > Core plug weeping oh blast |
| cobra_mark Member Since: 17 Feb 2015 Location: West Yorks Posts: 213
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18031
Talk about doing it the hard way!
Well it made me wince a bit perhaps the guy doing this thought it less hassle.
In reality it's a few peripheral parts the manifold studs and a few gaskets, from some of the pictures I have seen people leave the turbo attached and just support it and the exhaust as one. |
| Nick666 Member Since: 23 Mar 2016 Location: Somerset / Dorset borders! Posts: 81
Yea that's what I did - only tricky bit is if any of the exhaust manifold studs don't want to come out so you have to pull the manifold off them which means you need to move the turbo out of the way quite a bit (esp if THOSE studs don't want to come off either, which given the heat they certainly didn't for me!)
The video does seem like much more work to me, but as rightly pointed out, who knows what other issues were going on... |
| geobloke Member Since: 06 Nov 2012 Location: Nottinghamshire Posts: 4410
Does anyone know what size Allen/Hex key this plug is?
| dorsetsmith Member Since: 30 Oct 2011 Location: South West Posts: 4554 |
12mm
i will check in the tool box Last edited by dorsetsmith on 27th Mar 2017 12:33pm. Edited 1 time in total |
Thanks Dorsetsmith
just checked is 12mm
Good man.
What would you use to seal the new plug?
Depending on what image you believe, some new plugs come with a sealing thread lock and some without...
If it comes without I am probably going to use a wrap of PTFE tape. |
| ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127
Did my Disco with PTFE, no problems
Wanted, Forward Control Anything considered. |
Thanks Ian
PTFE it is, one thing is I don't want to taking this apart again in a hurry
