Home > Puma (Tdci) > rear wheel bearing
thrasher
Scotland 2007 Defender 90 Puma 2.4 HT Bonatti Grey
rear wheel bearing
think i have a rear wheel bearing on the way out,i took rubber cap off axle output shaft and gear oil came out so I'm presuming inner seal away,would seal leaking cause wheel bearing failure or wheel bearing failure cause seal to leak?
cheers gus
Post #612292 26th Mar 2017 6:30pm
zsd-puma
I suppose if the bearing was bad enough the radial movement in the half shaft wouldn't do the seal a lot of good.
But if the seal had failed then the axle oil is going to wash the grease out of the bearing.
Post #612342 26th Mar 2017 8:59pm
thrasher
thanks,was thinking along those lines,its just hard to tell what wheel bearing it is that's noisey but that made think that one was more likely
cheers gus
Post #612383 26th Mar 2017 10:09pm
agentmulder
Kuwait
As is, grab the top of the tyre, then with effort pull back and forward (left to right from vehicles perspective) until the whole vehicle is wobbling.
Aside from small suspension/bush squeaks and creaks you should not hear any noise (click clack, croink donk) from the hub...
Well, that was my idiot check after working on bearings/swivel housing anyway Thumbs Up
I did this with a series 3 I found on the side of the road for sale, 3 out of 4 gave a good 'cronk' - heh heh, maybe the one making no noise was the worst Laughing Solved the bowel problem, working on the consonants...
Post #612388 26th Mar 2017 10:20pm
A failed seal in the stub axle actually tends to improve bearing lubrication, but the migrating oil can sometimes get past the hub seal onto the disk.
In the "good old days" this is how the wheel bearings were lubricated and many people revert to this system.
Post #612395 26th Mar 2017 10:32pm
thrasher
well thanks,but I'm sure the oil getting past seal must have diluted the bearing grease I don't think there is play as yet but is only noisey at motorway speed
Post #612584 27th Mar 2017 4:53pm
True, but it's diluted it with gear oil which is just as effective and suitable as a lubricant. It also lubricates the outer halfshaft splines.
Post #612600 27th Mar 2017 5:52pm
