![]() | Home > In Car Electronics > Reversing Camera Positioning. |
zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720 ![]() ![]() ![]() |
On the back of the car.
In the cab. ![]() Seriously though, without a pic of what it looks like it's difficult to suggest, google doesn't bring up your exact model. I fitted my camera to one of the existing holes under the large hole in the rear cross member, so i can see the tow hitch and use it for coupling as well as parking. |
Riverboy Member Since: 16 May 2016 Location: French sector, Earth Posts: 1288 ![]() ![]() |
No idea what your system consists of but this is mine.
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
Sadi Member Since: 23 Jul 2015 Location: Windhoek Posts: 334 ![]() ![]() ![]() |
Also got the camera 🎥 mounted exactly above the rear window washing spout - as per Riverboy.
Monitor clamps on to the inside rear view mirror - obviously only for the model I got. Camera live wire connected to the same of the reverse light - activates only when reverse selected. |
I tend to keep my top rear camera on all the time, it gives a much clearer view of what his behind me than the mirrors do. I can still use satnav and all the apps if I need to. Not all systems have that option I know.
flydive Member Since: 27 Aug 2015 Location: Lugano Posts: 290 ![]() ![]() ![]() |
My set up (Puma)
Rear camera, temporary, will have to either move it or make a cover as it can be hit getting in/out of the car. ![]() Click image to enlarge Monitor, fixed with a strip of velcro ![]() Click image to enlarge |
Woodruffsdad Member Since: 16 Feb 2017 Location: Gloucestershire Posts: 29 ![]() ![]() ![]() |
Here is the link to the kit I bought: http://www.totalparts.co.uk/land-rover/grc...makes.html 2005 Defender 110 Td5 Special Vehicles Station Wagon Zambezi Silver With Black Roof And Black Wheel Arches/Eyebrows. |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 11007 ![]() ![]() |
Thats the same one as i got and i fixed the camera as they instructed under the number plate light
![]() Click image to enlarge and i made up a bracket for the camera for inside the cab ![]() Click image to enlarge This is fixed to the panel, so if i want to move it in the future i can just replace it with a new panel, hope this helps you a bit ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3752 ![]() ![]() ![]() |
![]() Click image to enlarge Ditto, as above, under the no plate lamp California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3838 ![]() ![]() |
^ Mine is the same as I didn't want to drill the car... Fitted in the number plate plinth
Great for reversing VERY close and hooking the trailer up ![]() ![]() Click image to enlarge ![]() Click image to enlarge |
LOL,, Need to adjust the viewing setting Stacey, to get the correct side
![]() But thats just the same reason i have mine on the plinth, with a manual override switch, to check view at anytime California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
Swine&Small Member Since: 20 Mar 2017 Location: Norfolk Posts: 1223 ![]() ![]() |
Hi
I have mine incorporated into the rear view mirror so that in comes on only when reverse is engaged.\ The camera is on the tow hitch plate ![]() 1967 Morris Traveller 1966 Morris Convertible 2012 VW T5 Camper Quod Abundat Non Obstat. |
It sounds as though you have the Land Rover Approved Trailair system. As well as the reversing camera you'll also likely have Tyre pressure monitoring for the car as well as the trailer - although the wheel sensors may now be missing.
Hello. Not familiar with the LR system that you mention ,mine was fitted by me last week. Supplied by mobile systems.
Tyre pressure monitoring sounds like the recent legislation introduced for cars, came in in 2013 I think? B 1983 Series 3 Pick up in Marine Blue 1967 Morris Traveller 1966 Morris Convertible 2012 VW T5 Camper Quod Abundat Non Obstat. |
TPMS and the coupling camera were part of the Trailair system, it was an optional extra but not all that common.
http://www.landrovertrailair.co.uk/ |
