![]() | Home > Maintenance & Modifications > Fixing Air Intake Grill so it can't fall off again |
| Supacat Member Since: 16 Oct 2012 Location: West Yorkshire Posts: 11018
Following on from my experience - and now others who have had the same thing happen:
http://www.defender2.net/forum/topic17458-15.html I decided not just to get a new one from the dealer and refit, even with the vehicle being very much under warranty. Looking in the parts book it appear the thing is held on with (3) insert & (6) bush: Click image to enlarge but on taking mine apart I only found one of the items present and from the photo it is hard to say which as they both appear to be identical. However, I only found 3 of the pins from the back grill - so 2 have made a bid for freedom - possibly down the air intake tubing: [URL=] Click image to enlarge[/URL] I decided to drill out where the tabs had been and insert bolts through c clips sitting on the wing edge of the air intake hole: Click image to enlarge Click image to enlarge I had to cut down the front edge of the c clips as it was showing around the edge of the grill when refitted: Click image to enlarge I put a little bit of copperslip on the internal threads of each c clip but not too much that it would end up coating the air filter Click image to enlarge Click image to enlarge So next job is to see if i can find those missing 2 pins :lol: Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
| Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6678
Nice mod
| farmer giles Member Since: 09 Feb 2011 Location: worcestershire Posts: 1299
watch out supacat, someone will be asking why your rivets aren't painted
| f15hie Member Since: 14 Feb 2013 Location: Kent Posts: 153
Came out 1 sunday morning to find it hanging on by 1 plastic spike, thought cant be bothered to take it to dealers although only 2 months old. So, out with the drill, drilled grille where the broken spikes were, pulled the broken spike out with pliars left the plastic retainers in and with 5 self tappers secured back. Used mrs black nail varnish painted screw covers and in 15 minutes back nice and secure
Click image to enlarge Anyway why arent the rivets painted :bow: Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
| Lambley Member Since: 20 Apr 2013 Location: Mid Devon Posts: 1435
Same thing happened to my old Defender, not a great design by LR.
I used a few blobs of silicone sealant to stop it coming off, never moved after that. |
| Mattyboy Member Since: 05 Dec 2012 Location: Sudbury Posts: 58
great idea, don't use supper glue like i did, it still fell off and just took the paint off the wing with it! 07 Defender 90 TDCI
98 Defender 90 300 Tdi Land Rover Freelander MG B GT CBR 600 AEC Matador but no washing machine |
Is that an "in" joke - which rivets are being referred to? |
shame on you! (the rivets next to the rear wheel arch on a 110 are fixed after factory painting so don't get a lick of paint) |
OK - thanks for the explanation - slow morning here
When considering whether I would use black screws or stainless bolts I did think the stainless bolts were nicely set off against the unpainted rivets...just didn't want to mention that on here |
| Farmer58za Member Since: 20 Jan 2017 Location: Worcestershire Posts: 85
Ha ha!
Today, a little "persuasion" on my TDCi air intake grill caused it to pop off. Yes, it was stuck on with the dreaded super glue! It's Saturday so I just cleaned off the cover at the lugs and fixed it in place with Silicone and duct tape. Tomorrow, I will remove the tape and it will be just fine. Regards David Dave's not here man... |
Supacat, that's a quality fix. You could also just drill the cover to match the air receiver plastic screw inserts and fig the receiver and the grid with the same (longer) self tapping screws.
Regards David
| All times are GMT |
