![]() | Home > Maintenance & Modifications > Parking sensors |
Paulv8 Member Since: 09 Jun 2013 Location: Milton Keynes Posts: 618 ![]() ![]() |
Fitted.
![]() Click image to enlarge V8 90...WIP |
Def90 Member Since: 17 Jan 2015 Location: Kent Posts: 268 ![]() ![]() ![]() |
Park Assist set up taken off a Discovery 2 and fitted into a modified rear step .
No issues as yet with fitting the sensors into a metal housing but the sensors do have a plastic casing. ![]() Click image to enlarge ![]() Click image to enlarge |
zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720 ![]() ![]() ![]() |
Other than perhaps with cheap kits the cutter they supply isn't able to drill metal, i can't see why you couldn't fit them in metal.
The circle you see on the sensors is the plastic/foam insulator, the middle bit is the actual echo sounder. The outer bit is literally just there to hold it in the hole. |
