Home > Td5 > TD52003 back seat broken
mustafasoleiman
United Kingdom 2003 Defender 90 Td5 XS CSW Indus Silver
The plastic bottom of one of the backseats is broken... Do you know where I can find a replacement?
Best
Alex
Post #610832 20th Mar 2017 11:27am
Martin
Site Admin
Yes, Land Rover. Part number ACC710320  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #610841 20th Mar 2017 12:26pm
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
I replaced mine a few years ago and they have cracked again, I thought about buying some 5mm acrylic and making my own. The price of the new genuine ones have gone up a lot as well!
Will 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #611021 20th Mar 2017 10:17pm
mk1collector
I'd make your own out of ply wood. Ray
My build thread
Post #611054 20th Mar 2017 11:35pm
lightning
Land Rover have biffed up the prices of a lot of spare parts.
For instance the rev counter has gone up from 85 to 300.
Post #611957 24th Mar 2017 11:01pm
Bearders
United Kingdom 2003 Defender 90 Td5 SW Bonatti Grey
I recovered all 4 rear seats 18 months ago and the mount points were broken on every base.
Seems LR changed from hardboard to plastic around TD5's, plastic are hugely more expensive so I went for hardboard, although the mount point for the rubber leg stopper was in a different place.
Have lasted so far but expensive for a bit of painted hardboard.
Other option I thought of was using black phenolic sheet, a substitute for tufnol. 400mm x 600mm x 4mm sheets available on eBay for just under 20 each and should be hugely stronger than original but would need length trimming and holes drilled (was planning to use best old one as a template)
Post #612884 28th Mar 2017 5:53pm
