Home > Technical > Can you fit a TD5 rad & Inter cooler on a 300tdi
Dieselhead
Not sure if this has been done, but sure its been tried
Now having a 90 to rebuild I keep thinking to myself all the things I can do with it when the time comes Cool
While rebuilding the front end of a 110 at work today, I wondered if the rad & intercooler from a td5 will work with a 300 tdi which is my engine of choice for the project
Thanks Thumbs Up Chris
2008 XS 110 2.4 Utility. Tonga Green
1953 Series 1 for restoration
1983 Mini Mayfair
2004 VW T5 Camper
2008 Diahatsu Sirion. Thats hers
Classic Bolens Garden Tractors
Post #611495 22nd Mar 2017 9:41pm
bankz5152
Yes friend of mine has fitted a TD5 full width intercooler to his 300tdi, standard rad though. So bit of work should fit!
Post #611594 23rd Mar 2017 1:22pm
Mo Murphy
Anything could be made to fit but why would you ?
50 Shades of Pennine Grey
Post #611599 23rd Mar 2017 1:41pm
bankz5152
A full size TD5 one is what 4x times bigger than the 300tdi one? Denser air, higher boost, more torque, less smoke
Post #611600 23rd Mar 2017 1:53pm
Mo Murphy
Sure but it's also thinner and the cooled air has to travel further through a hot engine bay. The Land Rover 90 - Many are called, few are chosen.
Post #611661 23rd Mar 2017 6:47pm
bankz5152
What? A full size TD5 IC is covers the majority of the front grill and sits infront of thr rad. Its literally the first thing bar the grill to hit the air.
Post #611783 24th Mar 2017 10:28am
jst
internally i dont believe there is much difference between volume of a tdi and puma/td5 intercooler. i looked at this a few years back.
with fitting the td5 inter you will need to rejigg pipework to bring it back across from drivers side to the inlet/turbo compared to std 300tdi Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #611815 24th Mar 2017 12:28pm
shaggydog
Also remember the Tdi Radiator has an oil cooler built into it which you will loose if you change to a Td5 Radiator.
If it was me I would fit a double thickness intercooler from someone like Allysport or bas tuning.
I'm not convinced of the need though, a good running Tdi has enough power for most things Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #611828 24th Mar 2017 1:47pm
jst
i think Mo means the pipework has further to go across a hot engine bay here rather than location of the IC wrt to the post below his. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #611843 24th Mar 2017 3:05pm
Dieselhead
Thanks for the replies guys
It only crossed my mind & sure it could be done.
I had a 300 tdi 110 years ago & that went very well for what it was & was standard Chris
1983 Mini Mayfair
2004 VW T5 Camper
Post #611881 24th Mar 2017 7:08pm
