![]() | Home > Maintenance & Modifications > wheel bearing maintenance and brake pads change |
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2111 ![]() ![]() ![]() |
Hi there!
The 40,000 km maintenance includes a wheel bearing maintenance (grease and checking) and change the brake pads in the four wheels I receive the invoice some days ago (not paid yet until all the clutch problems were cleared) They are charging me 8 hours of labour for all this work. I found that quite excesive. Works includes according to the detail Greasing the bearing Dismount the wheel hubs hub maintenance Change brake pads Time for each labour were not provided Any tought about the time to do this work? Thanks ! Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
jhnharvy773@gmail.com Member Since: 26 Feb 2011 Location: Hawaii Posts: 3 ![]() ![]() ![]() |
I need to replace my wheel bearings on my 06 Jeep Liberty, i have found a site that sells them the cheapest, i wanted to know if it is simple straight forward or if i will require a hub puller? let me know how difficult this is going to be??? Thanks |
Does an 06 Jeep Liberty have the same bearings as a Defender? 130's have feeling's as well you know
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2490 ![]() ![]() ![]() |
One hour each wheel. Done it. 57 mm spanner tube (ebay, paddocks, etc). Grease, gasket and torque wrench.
Internal axle seals in case. Anyway if you have not been wadding you could waint until 80000 km. Mine look just fine. Puma 110" SW ............................................................. Earth first. Other planets later |
