Home > Td5 > Mystery switch
Rosewellian
Mystery switch
Now the proud owner of this 2004 beaut! Can anyone help me identify the mystery switch which is placed in the rectangular recess below the radio. Small red light appears when switched in.
Thanks ian
Post #610679 19th Mar 2017 8:43pm
JAY BOY
Wales
Hi and welcome
Do you have a picture
Post #610680 19th Mar 2017 8:44pm
Lancerdoc999
Self-destruct button. Whatever you do don't push it!
Post #610755 19th Mar 2017 11:13pm
Outlaw1
England 2010 Defender 110 Puma 2.4 USW Santorini Black
Ejector seat ?
Post #610760 19th Mar 2017 11:35pm
mk1collector
That's not a factory switch so could be anything that the previous decided to fit. Best bet is to trace the wires from it and see where they go. Ray
My build thread
Post #610761 19th Mar 2017 11:36pm
Paul55
England 2008 Defender 90 Puma 2.4 XS CSW Santorini Black
Land Rover assist button Whistle Cogito ergo sum
Post #610765 19th Mar 2017 11:49pm
Lancerdoc999
does switching it on and off do anything? Can you get at the wiring behind the dash? If you have those DIN removal tools you could take the radio out and maybe you'll see something. (or can you remove the front fascia on the 2004?)
Post #610922 20th Mar 2017 7:05pm
Rosewellian
Thanks for your response. Doesn't seem to do anything.at first I thought it was something to do with alarm or towing electrics. I have seen another parked up defender with same switch in same place.
I have asked the garage I bought from to contact previous owner to try and solve the mystery
Post #610935 20th Mar 2017 7:41pm
bob neville
Similar type switch to that used on Exmoor Trim heated seat pads so maybe that.
Only other thing I can think of is on/off switch for driving lights.
2013 Defender 90 CSW - sold
Post #610938 20th Mar 2017 7:48pm
It's the small red light switch!
Has the vehicle ever had a winch fitted? I've seen similar switches used to energise a solenoid to power a winch.
Post #610952 20th Mar 2017 8:18pm
Rosewellian
Can't see any evidence of winch or driving lights being previously fitted. If the garage I bought from can't find out from previous owner I will go down the tracing the wires investigation.
Post #611244 21st Mar 2017 10:31pm
VeeTee
Netherlands
It activates the Flux Capacitor! Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #611288 21st Mar 2017 11:59pm
Huttopia
Does the vehicle start with the switch in both positions? Just wondered if it isolated the ignition / fuel pump or similar as a layer of security.
Post #611289 22nd Mar 2017 12:06am
Clive
United Kingdom 2004 Defender 90 Td5 X-Tech LE Zambezi Silver
It looks like the same type of switch supplied with the GKN overdrive except that they normally come mounted on a replacement gear knob, try flicking the switch when doing over 30mph.
Otherwise as said before, could be anything, you would need to trace the wires back to see where it goes.
Post #611370 22nd Mar 2017 1:23pm
geobloke
Nope. Definitely after market and the only thing to do is pull it out and trace the wires... Great job for a quiet hour this weekend...
Post #611619 23rd Mar 2017 3:38pm
