Home > Maintenance & Modifications > Rear door replacement? Any advice?
BCdefender
Canada 1999 Defender 110 Td5 CSW Orkney Grey
The time has come to replace my rear door. It's rusted all the way through and causing a rust stain on my stainless steel runners Whistle
Has anyone had experience with replacing the rear door? Any idea on part numbers and what it actually comes with? I have a 1999 TD5 but I think the puma door will fit.
Thanks! 1999 Defender 110
2003 P38
2007 RR SC
"And that's why it needs to be celebrated, because when the Defender goes we'll have lost this pointer to where we came from, and we're really going to miss it."
My build thread: http://www.defender2.net/forum/topic47750.html
Post #610469 19th Mar 2017 2:45am
zsd-puma
i think the Puma door will fit too, the hole is the same as are the latch and hinges.
If fitting a Puma door you'll also need the glass and seal, as well as the internal trim panel as they're all a different fitment.
If you order a replacement door from LR you'll get just that, a door in black e-coat with nothing attached to it, no glass and no bolt ons or electrics at all.
Post #610537 19th Mar 2017 1:37pm
BCdefender
I was afraid that was the case... I wonder if I can save the electrics and the glass? The latch etc is all new already. If that's the case I would just need the trim and to paint the door. Rolling Eyes 1999 Defender 110
2003 P38
2007 RR SC
Post #610578 19th Mar 2017 4:29pm
zsd-puma
If you bought a new TD5 spec door then you could reuse everthing.
However the Puma door uses a completely different glass, so you would need a new glass. The Wiper motor etc would 'probably' be the same but i'm not 100% sure.
The puma door is a worthwhile upgrade, as the older doors are made in two peices, they were pretty rot prone.
Buying a second hand Puma door with everything attached and having it refurbished is probably a good option.
Post #610583 19th Mar 2017 4:43pm
CDN38
Canada 2000 Defender 110 Td5 SW Bonatti Grey
Pretty much nothing swaps over from a Td5 door to the Puma. Wiper motor, glass, hi level brake light, door card, all different.
There is no comparison between the older Td5 door and the Puma. The strength of the stamped frame is far superior, (but it's still best to run a tire carrier to avoid excessive wear on the hinges). No galvanic corrosion between the skin and frame, much more modern and solid doorcard, and a window seal that doesn't look like it came from a meccano set.
Either way, you'll be in for paint, so it would be a good time to look for anything else bolt on that may need a refresh. Could be a good time to upgrade door hinges if they are rusty, paint them all together with the door. it's a Landrover thing...
my renovation thread:
http://www.defender2.net/forum/topic40792.html
Post #610648 19th Mar 2017 7:30pm
BCdefender
Gore hinges.... hmmm. Rolling Eyes 1999 Defender 110
2003 P38
2007 RR SC
Post #610658 19th Mar 2017 7:56pm
Intercept
United Kingdom 2002 Defender 110 Td5 Black LE Java Black
I have no experience of the rear door equivalent, but I've recently fitted SP4x4's galvanised frame, steel skinned front & 2nd row doors to my Td5 DCPU. I was impressed with the quality and fit so I'd expect the rear door to be just as good.
https://www.sp-4x4.com/DEFENDER_GALVANISED...-steel.htm
The complete range is here.
There are a few photos of my door install job in this thread.
John
Post #610851 20th Mar 2017 2:06pm
BCdefender
Wow thanks Intercept! Bow down
I am going to take a look into their products. They replied back extremely quickly and everything from my TD5 door will transfer over to their door. 1999 Defender 110
2003 P38
2007 RR SC
Post #613191 30th Mar 2017 2:17am
