Home > Technical > Switch for LED Bar
Baffled 1
United Kingdom 2002 Defender 90 Td5 HT Epsom Green
Switch for LED Bar
Good evening all, I have fitted a full length Led bar on the roof of my 90. Now it's time to start thinking about wiring to a switch, but just before I start cutting and adding wiring is it possible to wire into the genuine aux switch (YUG000540LNF) I have found the write up for the aux switch but it's for 2 spot lights connected to full beam, would it be wired the same although I will not need it to be wired to the main beam just on off.
Thanks for any help.
Post #610613 19th Mar 2017 5:33pm
I got rid of the 2 spots and plugged LEDs into the existing loom. Once you use the light bar, you'll not be needing the spots again Thumbs Up QRZ M8VPF
Post #610616 19th Mar 2017 5:37pm
