Home > Maintenance & Modifications > Roof Replacement
barrowg
United Kingdom 1990 Defender 90 200 Tdi HT Corris Grey
Roof Replacement
About to replace the roof on my 90. Just wondering if anyone knows if it's a good idea to put a line of silicon around all the joints, or does it seal by itself pretty well. Any other tips on replacing it would be really helpful
George
Post #610512 19th Mar 2017 10:57am
gilarion
No need for any sealant as the rubber/sponge roof seal does a pretty good job.
Easy enough to take off and put back a roof though the more hand help you have the better, I have always found the best way is to lift it up from the back and pivot the roof on the front window frame then just lift of.
Helps if you have a long reach 10 mm and 13mm socket to take off all the bolts. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #610531 19th Mar 2017 12:57pm
zsd-puma
If you really must use a sealant, use an automotive seam sealer, not silicone. If you use silicone and you ever need to repaint the area around it, then it will be a total nightmare.
Post #610535 19th Mar 2017 1:34pm
barrowg
Helps if you have a long reach 13mm socket to take off all the bolts.
Cheers thank you
Post #610536 19th Mar 2017 1:37pm
gilarion
Just an edit you will also need a 10mm socket for all the M6 bolts as well. As a rough count I think there are about 36 of the M6 roof fixing bolts For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #610538 19th Mar 2017 1:53pm
Paul55
England 2008 Defender 90 Puma 2.4 XS CSW Santorini Black
Slight hijack of thread, if the roof was being resprayed the original colour, would it be ok left on and just replace with new alpine seals? plus if it was being painted another colour would the roof then need to come off?
Paul. Cogito ergo sum
Post #610543 19th Mar 2017 2:08pm
barrowg
How quickly can it be done alone?? If possible
Post #610544 19th Mar 2017 2:08pm
gilarion
I am not too sure roof removal is a job for one person! The roof is quite heavy though it is not so much the weight just the size of the thing that would make it awkward for one person plus the front of the roof goes into a lipped seal that really needs the roof to be jiggled about a bit to get out of the seal particularly if the seal is old.
I would recommend two people minimum to take a roof off and definitely two people to put the roof back on.
I suppose it could be possible for one person lifting it up from inside slowly, then going outside and slowly sliding it off, but the risk of damage will always be there in a single persons operation especially putting the roof back on.. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #610566 19th Mar 2017 3:42pm
gilarion
Paul.
Provided you masked up well then I would not see a problem with spraying the roof a different colour with the roof left in situ.
Alpine seals can be a sod to replace so make sure you buy the special tool, and use plenty of washing up liquid on the seal when replacing For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #610570 19th Mar 2017 3:48pm
