Home > Td5 > TD5 turbo heat shield bottom bolt seized
AndyT66
England 2004 Defender 90 2.5 TD XS CSW Zambezi Silver
Hello all, went to remove the turbo heat shield and have been thwarted by the bolt that you access through the hole in the back of the shield. It's seized solid and i think I've started to round the bolt head. Any tips anyone who may have struggled with this? Thanks Andy
Post #610334 18th Mar 2017 6:49pm
dorsetsmith
heat the bolt or drill down centre bolt and use screw extractor
right Censored of job i no
FB108087 [ 2500 cc - 5 Cylinder - Diesel - Turbo - M8 x 40 - flanged head ]
Post #610340 18th Mar 2017 6:57pm
JustFX
United Kingdom 2000 Defender 110 Td5 CSW Coniston Green
Drill the rivets out. It's a nightmare of a bolt to remove. It holds well on the mounts on the engine alone. Ran my Disco for several years like that. If you want you could tap a thread into the bracket once the turbo is off as it has plenty of meat on it.
Post #610348 18th Mar 2017 7:16pm
AndyT66
Thanks gents for the suggestions, it was one of those afternoon jobs that ground to a halt. I'll have another go tomorrow followed by the drill
Post #610454 18th Mar 2017 11:53pm
JustFX
Did you manage it?
Post #610596 19th Mar 2017 5:41pm
AndyT66
Not quite ! Stumped again by the need for a right angle drill for the two rivets nearest the bulkhead on the other side of the of the offending bolt access hole. So nearly there. Smile
Post #610636 19th Mar 2017 7:17pm
AndyT66
Post #610637 19th Mar 2017 7:19pm
JustFX
Dremel and a grinding wheel?
Post #610698 19th Mar 2017 9:29pm
MadTom
Czech Republic 1999 Defender 130 Td5 HCPU Baltic Blue
I had the same problem two weeks ago. Solution was to use a chisel to "cut" rivets and than grind down head of the screw.
To replace the heat shield, I have riveted is back, and I didn't use the screw any more. With proper twist, the heat shield holds well. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #610826 20th Mar 2017 10:41am
AndyT66
Many thanks for your tips, next weekends job now. Possibly going to try and drill out leaving the bracket attached and then reattaching with 4 small bolts (say m4) or self tappers?
Post #611011 20th Mar 2017 9:55pm
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
I use a set of Irwin bolt grip sockets really good, might be worth getting the engine warm first the give it some heat!
Will 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #611038 20th Mar 2017 11:06pm
AndyT66
Thanks Will, spotted those in the toolstation catalog for ~20. I'll give that method a go
Post #611296 22nd Mar 2017 12:53am
bankz5152
I cut mine off with a grinder. You don't need it.
Post #613066 29th Mar 2017 3:52pm
TJH1985
Just had the same problem Big Cry
After longer and longer bars I finally gave up, went for a run as will suggested and got everything nice and hot pulled on the drive and it came straight out with just a hand ratchet.
Might help someone who finds this thread like me. Thumbs Up
Post #678439 14th Jan 2018 8:19pm
Dieseljock
Scotland 2003 Defender 90 Td5 HT Zambezi Silver
I'll second the irwin grip sockets I've got the snap on set up to 27mm they have been one my best purchases. They have got me out of many a hole working on tractors and plant and of course the defender.
Post #678501 14th Jan 2018 10:20pm
