![]() | Home > Maintenance & Modifications > What is this accessory for ? |
Augusto Member Since: 01 Feb 2011 Location: Munich Posts: 35 ![]() ![]() ![]() |
![]() What is this accessory for ? How does it work ? How much ? Where to order? Thanks, Augusto. Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() Last edited by Augusto on 24th Feb 2011 5:53pm. Edited 2 times in total |
Stops the snow / various crap from filling up heater intake Original Member Pie n Pea Club.
110 HCPU Tipper |
lrmaniac Member Since: 04 Feb 2010 Location: Lisboa Posts: 764 ![]() ![]() ![]() |
You just screw it with the existing bolts ...
It cost me 100€, 6 moths ago ... bought here in Portugal .... don't know where it came from ... It's sold by Entreq, a site sponsor ... ![]() Click image to enlarge very usefull ! ![]() Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. |
Thankyou.
It is quite expensive but if you suggest me I will think about it. thanks again. |
WarPig Member Since: 05 Dec 2009 Location: Sheffield Posts: 1748 ![]() ![]() ![]() |
I bought mine from P A Blanchards ebay shop
http://cgi.ebay.co.uk/Land-Rover-Defender-...20b6c710c8 Their advert says they will post worldwide, but best to ask them first. When ordering/paying be sure to specify if its for a left or right hand drive vehicle. Mine came bare metal which Im getting sprayed when my 300tdi gets resprayed soon. |
on about the air intake, check inside now and again as there is a rubber 'valve' at the back of intake to let rain water etc drain out, this gets glogged up and can lead to the water being drawn into the heater then onto the passenger footwell. 2.4 90 XS
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
On the Puma there are two rubber valves (Teet's?) on the heater intake box, unless they where removed at PDI that is.
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 510 ![]() ![]() ![]() |
'Snow Cowl' - as fitted to the Royal Marine's original Winterised 110s, Royal Netherlands Marine's 110s, Winter/Wading Wolf XD, as well as the Courtaulds Aerospace CAV100 (now known as NP Aerospace CAMAC CAV100), also called 'Snatch' by squaddies and the press.
Available as LH or RH fitment from Land Rover for silly-money (I have the part numbers somewhere) I got mine direct from Courtaulds Aerospace back in the early 90's I had to buy 10 to make up the minimum order value, so I ordered 5 x LH and 5 x RH, kept one of each for myself and sold the rest. Here are mine fitted to my 110 (the LH one doesn't really do anything, but it 'evens-up' the front end ![]() ![]() ![]() ![]() ![]() . Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
2? 2.4 90 XS 1968 1/32 scale Britains 109 Pick up. |
![]() Click image to enlarge Grockle, there is one under the heater fan unit and you need to push in past the hoses to get too it (Left arrow). The other one is just under the plastic intake duct (Right arrow) towards the rear. |
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 ![]() ![]() ![]() |
I took both mine off unless you are going wading very deep they are not needed |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6215 ![]() ![]() ![]() |
RRC 6817 Chamois cover intake £216 ![]() RRC 6818 Chamois cover intake £216 ![]() |
nakatanenga Member Since: 12 Nov 2010 Location: Neumarkt Posts: 546 ![]() ![]() |
Mid this year there will be a version made of ABS plastic in LHD and RHD for a VERY reasonable price. The good side on the plastic one is that it will not punch 2 holes in your wing in case of a minor "off road accident" like the metal one does. WANTED:
SII or SIII in max 1.5k |
So what else is coming this year then
