![]() | Home > Technical > Reverse light switch |
Miggit Member Since: 09 Mar 2017 Location: Milton Keynes Posts: 72 ![]() ![]() |
^ I don't want to state the obvious.. but the OP did say that the defender was an ex MoD one and had no reversing lights fitted.. so there's a chance that they missed the wiring too
![]() Anyway this is the switch for the early RRC LT77 box, and it says all LT77 to 1990 http://www.ebay.co.uk/itm/RANGE-ROVER-CLAS...5b34d1d392 It then goes on to say in the description that the early ones are 28mm and the later are 14mm... so in my books that leaves 14mm of thread on the outside... that's enough to get 2 full nuts on, let alone 1 ![]() ML 270CDI |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17844 ![]() ![]() ![]() |
You could fit a manual switch on the dash provided that it incorporates a warning light.
Barneyboy Member Since: 19 Nov 2014 Location: Exmoor Posts: 1636 ![]() ![]() ![]() |
hi yes that would of been the plan if it couldnt of been retro fitted, ive done that with 3 of my old series land rovers with no issues come mot time
zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720 ![]() ![]() ![]() |
there wont be any issues at the MOT as the reverse light isn't part of the MOT test at all - you don't even have to have one and if you do it doesn't even have to work for the MOT. However cars built after about 1979 (i've not checked the year) are supposed to have a reverse light fitted by law, so you would be breaking the law by not having one fitted or not working - but you'd still pass an MOT, as it's not in the test. It's like spare tyres, they're not checked in the test at all either, they can be bald, punctured and perished and the car still passes the MOT. ![]()
You could, but as the gearbox has the point for the switch to screw into, it's no more work to fit an automatic switch. |
It was just a suggestion on the basis that various cars from the old BL stable would be a source of a reverse switch, who knows what folk have knocking about in the back of the garage. ![]() |
Hi that's interesting re the law as my ex military 90 does not at the moment have a reverse light which is why I started this thread,I'm assuming it hasn't ever had one fitted,it would be good to know either way
![]() Answer........ no one, they are not a legal requirement, which is funny cos since 2012 they are a requirement on all new trailers that are made... could be interesting.. There is a Law about showing white light when going in a forward direction... which is why a simple manual option isn't always the best option... I prefer the automatic route and let the gearbox determine when the lights should be on or off! RRC 2.4 TD... it's either a stretched 90 or shrunken 110!! ML 270CDI |
Because it's not in the MOT test. I mean how many people can produce an MOT failure sheet for running red diesel? Just because they can't it doesn't make running red diesel on the road legal.
You'll find all cars built after about 1979 have them fitted, because they wouldn't have passed type approval without them. Whether you'd actually get pulled over for it is another question. Trailers don't have MOT's at all (below a certain weight), the reason new ones need reversing lights it for type approval purposes. Military vehicles had exemptions for a number of things, presumably a reverse light is one of them. |
Not all gearboxes are drilled and tapped for the switch. If you use a manual switch the law requires a tell-tale either in the switch or on the dash to indicate to the driver that the reversing light is on, |
Right having trawled through some of the road traffic act, and lost the will to read, I have discovered that reversing lights are classed in the UK as "Optional lighting" so there is NO legal requirement to have them fitted. Type Approval is a bloody EU thing, so while they might be a legal requirement in the EU, they are optional in the UK. However the UK law does state that if fitted they either need to be operated by the gearbox when reverse is selected, or, fitted with an indicator (tell tail) if operated manually. RRC 2.4 TD... it's either a stretched 90 or shrunken 110!! ML 270CDI |
The UK is in the EU - for now. It comes under UNECE (actually a United nations convention on vehicle construction, originating from the EU.) You can read it here in a well presented Hella published document; https://www.hella.com/hella-com/assets/med...LLA_EN.pdf ECE-R48; Reversing lamp ECE-R48 section 6.4 and ECE-R23 Presence ECE-R48 § 6.4.1 Mandatory for all passenger car classes. Number ECE-R48 § 6.4.2 1 device mandatory and a second one mandatory on M1 vehicles and all other vehicles with a length of <6> 6 m, except M1 vehicles. Color ECE-R48 § 5.15 White Position in width ECE-R48 § 6.4.4.1 No regulations Position in height ECE-R48 § 6.4.4.2 Min. 250 mm, max. 1,200 mm. Visibility ECE-R48 § 6.4.5 1 lamp: horizontal ± 45°. 2 lamps: horizontal 30° inwards to 45° outwards. Vertical 15° upwards, to 5° downwards. Electrical connections ECE-R48 § 6.4.7 Only lights up when the reverse gear is engaged and the vehicle is in running order. The special conditions in section 6.4.7.2 apply to the optional reversing lamps. Tell-tale ECE-R48 § 6.4.8 Optional * Installation of the two optional reversing lamps also allowed on the vehicle side. Last edited by zsd-puma on 17th Mar 2017 8:24pm. Edited 1 time in total |
True, although the OP has pointed out his does have a bolt screwed in where the switch goes. |
Sorry, I wanted to walk away from this but it's really bugging me.... The MoT is a test of "Roadworthiness"... it is to ensure that a vehicle complies with the current laws of the road, there is no requirement for a UK built vehicle to be fitted with reversing lights.. if there was a requirement, i.e. legislation, it would be part of the MoT test. The requirement for a reversing lamp is EU.. therefore if a manufacturer wanted to produce a vehicle and sell it within the EU it must have reversing lights... As the Defender 110 is produced for the MoD in the UK by a UK manufacturer for use in the UK, it does not need reversing lights... furthermore it also does not need reversing lights to travel in any other EU Member State as there is an exemption clause for military vehicles. Driving on Red Diesel is not a Roadworthiness issue, it is covered by HMRC and is classed as a Criminal offence, "failing to pay road fuel duty" and can result in the seizure of the vehicle, fines, and imprisonment.... it will however not result in penalty points on your driving licence as it is not an offence under the "Road Traffic Act". The long and short of it is, if they are fitted they must only work when reverse gear is selected... any forward motion of a vehicle with illuminated reversing lamp is illegal. However going backwards with fitted reversing lamps not on, is not an offence, and using a vehicle without reversing lamps is also not an offence too. RRC 2.4 TD... it's either a stretched 90 or shrunken 110!! ML 270CDI |
I'll say again the UK is in the EU..... (whether you like it or not) building and selling a car in the uk is building and selling a car in the EU.
The mot hasn't got anything to do with the legality of it, Take aftermarket HID headlamp bulb conversions, they're illegal for road use. However they will pass an mot if the beam pattern is correct, that doesn't make them legal. There are exemptions for military vehicles, however when that vehicle leaves military service it's no longer a military vehicle. UNECE rules are posted above. |
