Home > Maintenance & Modifications > EGR after remap to blank or not to blank
Dean Watson
United Kingdom 2011 Defender 110 Puma 2.4 XS DCPU Stornoway Grey
Hi all
just had a remap from BAS ON 2011 double cab, more than happy with the result, question is :
is it recommended to blank off the egr now its been deleted or not or just switch maps back every now and again to let it run.
Also if its recommend to blank then does anyone have any pictures of where it goes?
thanks
dean
Post #609814 16th Mar 2017 12:18pm
bankz5152
Blank it off but keep the gubbins that come off just incase they change the rules.
Post #609826 16th Mar 2017 12:58pm
williamthedog
You don't have to take anything off.
You put a blanking plate after the egr cooler just before the egr valve itself.
Takes about a half a hour to fit Thumbs Up
Post #609864 16th Mar 2017 4:23pm
proloForêt
France 2008 Defender 90 Puma 2.4 XS CSW Java Black
Hello I must doing also this job. I think on the weekend. I am looking for tipping for this job. Is there some conversations on this job. My english stops the searching tool to work well Laughing
I am deciding that to do off the hood is a good option and to sit me on the engine to undo the lowest bolt. I cannot reach from under.
Léo
Post #609888 16th Mar 2017 6:40pm
I've been running a BAS no-egr map for getting on for 7 seven years and 150,000 miles and did nothing to the EGR, I simply left it alone. It is unlikely that it would work properly after 7 years of inactivity, but since I have no intention of reverting to the original map I don't see it matters. I have never had any problems with my inert EGR.
Post #609892 16th Mar 2017 6:50pm
LR90XS2011
it is a simple blanking plate that slides in, if you put EGR blank into EBAY they are a couple of pounds DEFENDER 90 TDCI XS,
Post #609893 16th Mar 2017 6:58pm
zsd-puma
Blank it off, as you don't know for sure that the EGR is fully closed, it might be stuck partially open.
I was tempted to blank mine and remove it all to declutter the engine bay, but as Bankz5152 says, they might change the rules in the same way they have for Catalytic converters - ie a visual check to see if the EGR has been removed.
Post #609917 16th Mar 2017 8:14pm
jst
does anyone have a picture of where the blanking plate goes?
Doe those allen bolts come undone easily normally or does it become an issue? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #610013 17th Mar 2017 9:27am
proloForêt
Hello,
I see lots of times BAS. What is BAS please?
Thank you
Léo
Post #610017 17th Mar 2017 9:30am
^^ BAS = Bell Auto Services https://bellautoservices.co.uk/
Run by Pete Bell, creator of remaps and other high-quality engineering upgrades for Landrover vehicles.
Provided that the EGR is currently closing properly, there really is no need to blank it off when upgrading to a no-EGR map.
Post #610022 17th Mar 2017 9:49am
SimonDavies
Wales 2010 Defender 90 Puma 2.4 HT Zambezi Silver
Quick question, if blanking with a BAS remap, is it the 'fully blanked' plate I should be fitting, as apposed to the plate with a small centre hole. Thanks
Post #610286 18th Mar 2017 11:39am
Full blank. Thumbs Up ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°*\\_
Post #610289 18th Mar 2017 11:57am
SimonDavies
Thank you Steve.
Post #610404 18th Mar 2017 8:10pm
Dean Watson
egr blank
does anyone have a pic of where to fit?
Dean
Post #611116 21st Mar 2017 12:32pm
This thread maybe of help and interest:
http://www.defender2.net/forum/topic5673-30.html ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
Post #611129 21st Mar 2017 1:36pm
