Home > Maintenance & Modifications > crossmember seat belt brace bolts
Piggle
2003 Defender 90 2.5 TD XS CSW Bonatti Grey
Hi all - planning a sanding down and refurb of the rear cross member on my TD5 90. I have rust around the bolts either end of the rear crossmember - which I understand are for the seat belt brace bar. I'm guessing I need to retain these as I have Exmoor forward facing seats in the back.
If I remove these bolts to better access the rust, are they straight forward to simply screw back in afterwards, or a nightmare?
Thoughts/ tips very much appreciated.
Piggle
Post #609810 16th Mar 2017 1:11pm
agentmulder
Kuwait
Did similar recently.
No issues removing the brace bar on my 2008 puma. Even though the puma is newer it has been problematic on occasion with dried up/corroded up bolts being a chore to remove intact, but these weren't.
There are two compression tubes inside (to stop the bolt tension from crumpling the crossmember) that might fall out of place, but mine were nicely held in by dirt, yours likely will be too. Nothing a podger or driver cant hold in place though, simple stuff.
Have fun Thumbs Up Solved the bowel problem, working on the consonants...
Post #609817 16th Mar 2017 1:24pm
dorsetsmith
Post #609820 16th Mar 2017 1:38pm
Piggle
Great - thanks both!
I'll give it a go - what could possibly go wrong....
Post #610045 17th Mar 2017 12:20pm
