![]() | Home > Technical > Puma fuel gauge stopped working |
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 ![]() ![]() ![]() |
So the fuel gauge packed up Sunday, a warning 'pinging' noise accompanied by the needle on zero and the fuel light on ... Knew i had qtr tank but stuck another £30 in just to be sure
![]() Was hoping it was a glitch, but 3 days later it's still the same ... Is there a 'known' common problem, or is the tank going to need removing??? Guns and Landrovers .... anything else is irrelevant. |
Thanks for that Blackwolf
![]() Drives fine at the moment, not missing a beat [hope it stays that way until time allows repair] ![]() |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17731 ![]() ![]() ![]() |
It would be interesting if you could let us know if you do get any odd effects running like this. If the LR published information is correct, it should begin by inducing a simulated "fuel starvation" misfire, which will clear on cycling the ignition for a few times, then persist, and ultimately then inhibit engine start to prevent the system completely running out.
I don't know if it is clever enough to determine that a sudden transition from plenty of fuel to zero fuel can only be due to a fault (or, I suppose, theft) and therefore inhibit the strategy, or if it will assume that you're running out and behave as predicted. |
I will
![]() It's going to be a good while before it gets looked at so we'll soon know ![]() |
73 miles later and It's still driving as it should
![]() Does this point towards the sender unit being fine and It's more likely a gauge/wiring issue?? Guns and Landrovers .... anything else is irrelevant. |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20775 ![]() ![]() |
Have you checked the plug on the rear of the IPAC is secure? WeWillWinπ¬π§πΊπΈ
β½οΈπ’οΈβοΈπ§°πͺ |
Steve makes a good point, perhaps the issue is at the IPAC not the sender or ECU. If it is a sender fault and the ECU thinks the tank is empty, I am very surprised that it is still running.
It would be interesting to hook up a diagnostic tool and see what fuel level the ECU is reporting. If it is not empty, it points to an IPAC problem. |
I did unplug the cluster for a few minutes and re-connected [just in case] Also disconnected the battery for 10 minutes ... both made no difference.
I don't have any diagnostic tools good enough for that sort of info on a Defender ... ![]() I'm with the Bro in law at the weekend, I assume I can temporarily swap the ipac for his one just to see if gauge works Blackwolf? Or are they specifically programmed to each individual vehicle's ecu? Ta Guns and Landrovers .... anything else is irrelevant. |
![]() Click image to enlarge ![]() Click image to enlarge with your ins cluster unplug you also can comm check wiring and fuel tank sender with multimeter ![]() Click image to enlarge Plug C0390- pin 11 and pin 10 Plug C0114 - pin 1 / 2 is the one on top fuel tank Last edited by dorsetsmith on 20th Mar 2017 6:50pm. Edited 2 times in total |
Since the IPAC is an integral part of the security sytem (with the AS10 and ECM) I doubt you can just swap one over, unfortunately.
I was going to suggest a manual check, just thought checking the plug for the IPAC would be best to try first.
The diagram makes that task all the better. ![]() β½οΈπ’οΈβοΈπ§°πͺ |
Had a very quick look yesterday.
IPAC is fine, gauge works if plugged into bro in law's puma, his IPAC doesn't work in mine. Assume It's not sender unit [As vehicle is still driving faultlessly] so that only leaves a wiring issue somewhere [I feckin HATE wiring issues!] It can stay like that til I can be bothered .... ![]() |
Could possibly be debris damage from underneath.
Hopefully it's not directly near the fuel tank. WeWillWinπ¬π§πΊπΈ β½οΈπ’οΈβοΈπ§°πͺ |
With the IPAC unplugged
check wiring in stages i.e. from your IPAC to the engine bay chassis harness plug with multimeter to start with, next chassis harness plug to driver side rear wheel arch not plug I no will have to unwrap harness and find two wires green / orange 0,75 and yellow / purple 0,75. I have used pins and the multimeter con check end to end both wires if ok at this point your wiring problem from hear to tank or the sender Using pins and the multimeter con check across the two wires see if you get reading i.e. fuel tank sender |
