![]() | Home > Maintenance & Modifications > TDI300 Turbo check and questions |
| itolond Member Since: 16 Jan 2016 Location: Singapore Posts: 193
Hi Forum,
delivering some TLC to the landy and before i start re-assy need some experience in regards to turbo. in the vacuum unit for the Waste gate i notice quite a bit of oil and 'soot' in the pipe leading to the intercooler (video of the turbo if you can take a look and see if there are issue) Click image to enlarge Video : https://www.youtube.com/watch?v=OHwFZOSCdwA |
Nobody, assum the turbo is ok.
I am not sure what good looks like |
| Mash Member Since: 09 Feb 2015 Location: Guernsey Posts: 1674
A small bit of lateral play is fine, if you have excessive movements vertically then this indicates wear, oil will be on the inlet but nothing excessive should be there.
How was the turbo prior to the strip down? Did you get good boost pressure? 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
| shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347
Small amount side to side is fine, needs to be none back and forth
Self confessed mileage hunter |
got it
