Home > Td5 > A puzzling problem
Page 2 of 2 <12
Chris86
United Kingdom 2005 Defender 110 Td5 USW Chawton White
Timing
@Grafty99
Was all set up with the correct pins etc when it was largely rebuilt in December/January by the independent guys.
Chris
Post #609229 13th Mar 2017 9:51pm
grafty99
The only other thing I can think of is oil in the injector loom/red plug in the ecu Question 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #609230 13th Mar 2017 9:53pm
Chris86
Oil in the Loom
It has never had oil in the loom as far as we are aware- certainly not in the time we have owned it (3 and a bit years and 35,000 miles)
I checked the plug when we viewed it- no oil present then, and I immediately changed the injector loom when I serviced it shortly after purchase to be sure that it had one of the improved ones fitted.
Im struggling to think what else it can be and options are becoming limited as to whet else to try, I had the FPR off about 18 months ago and I'm pretty certain the filter was clean then (I don't remember it being dirty so I assume it was clean- also it has been delivering consistent fuel pressure when on diagnostics.
Chris
Post #609233 13th Mar 2017 10:05pm
Chris86
Any more ideas folks? I'm pulling my hair out here.......
Chris
Post #609297 14th Mar 2017 8:52am
bob neville
When the new crank sensor was fitted did you fit the shim under it ?
There was a recall many years ago about the shim being missed on build.
2013 Defender 90 CSW - sold
Post #609402 14th Mar 2017 3:07pm
Messaged you Chris. QRZ 2e0vpf
Post #609411 14th Mar 2017 3:48pm
Page 2 of 2 <12
