![]() | Home > Maintenance & Modifications > Rear pads on a 1989 90 |
| Jim G Member Since: 21 Jul 2014 Location: Ormskirk Posts: 92
They are probably discovery 1 pads ( early / mid 1990's, ) maybe take one out and go and compare at Halfords or a friendly motor accessory shop ? 1984 300TDi hardtop Stornoway Grey
1984 200TDi hardtop..... soon to be a V8 .. but which V8 ? 1974 DAF T244 4x4 wagon converted to a motorhome 1976 Jaguar XJC with supercharged engine |
| rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2243
The notion of Halfords having brake pads in stock amuses me!
I believe that 90 and discovery rear calipers take the same pad type. To be safe whip the wheel off and have a look. They should be held in with two large split pins and two spring clips which stop them rattling. They will also have a tab which sticks out of the top. Make sure you get the non abs version if ordering for discovery as you wont need the wear sensor. I usually find brakeparts.co.uk good for checking the shape of pads before ordering as they have useful pictures. Steve 02' 110 TD5 Double Cab Rebuild Thread |
| JamesF Member Since: 10 Nov 2016 Location: Hitchin Posts: 71
Thanks chaps that is really helpful.
Will have a look this evening and see if I can make sense of it. |
| All times are GMT |
