![]() | Home > Technical > Hot relay holder |
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 868 ![]() ![]() ![]() |
The headlights have been playing up recently, it seems I've found the problem...
Any ideas why the headlight relay connection would get hot? Unfortunately there's not much spare wire to crimp new terminals on ![]() Click image to enlarge |
Wild Card 90 Member Since: 03 Dec 2014 Location: Gerlingen Posts: 1060 ![]() ![]() ![]() |
That looks like the one spade connection is getting hot. Remove the connector from the block and check to see if the wire and insulation is still ok. Cut off and replace female spade connector.
If the relay itself had a problem that caused it to heat up, the discoloration wouldn´t be so localised. 1998 Tdi 90 SW, 2008 Td4 90 SW, 2012 2.2 90 SW, 2" raised Trailmaster/Terrafirma Heavy Track Raids, 255 MT´s, Recaro CS´s, anorak, wellingtons |
Thanks for the replies
![]() The connector has got hot enough to anneal the spade on the relay so I would imagine the the terminal in the housing will have lost some of its spring. Ive just robbed some relay connectors out of a scrap Discovery and will fit one of them, I might be luck and have the same colour wire ![]() I still don't know why it got hot, as far as I can see from the wiring diagram there is little load on this relay. . ![]() Click image to enlarge |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20942 ![]() ![]() |
Is it 55w bulbs your using? Either way, Ceramic maybe helpful in this instance too.
And as suggested, I'd imagine hear build up due to high resistance. Edit* Sorry, just re-read you meant the Relay holder not headlight connector. Doh! ![]() Maybe still a good idea though all the same. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°*\\_ Last edited by custom90 on 12th Mar 2017 12:17pm. Edited 1 time in total |
I will have a go at a repair when it stops raining...... if
![]() I also have a Boomslang loom ready to fit ![]() |
zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720 ![]() ![]() ![]() |
A bad earth would do it
The plastic housing will likely be brittle too, so it's worth swapping that for one of the spares you have. |
your right munch beater
http://www.polevolt.co.uk/acatalog/info_RBW1U.html Last edited by dorsetsmith on 12th Mar 2017 4:48pm. Edited 1 time in total |
Durite do some quality bases too.
Some if it on the market is Chinese rubbish ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°*\\_ |
Can anyone tell me where the earth is on this headlight circuit?
2005 TD5 if that makes a difference |
![]() Click image to enlarge behind coolant expansion tank |
Brilliant
![]() I'll go and have a look now! Edited to add: The earth point looks OK and is tight, I will take the terminal off and clean it up when I get a chance and it stops raining |
pme Member Since: 06 Jan 2016 Location: cambridge and mainly ariege Posts: 49 ![]() ![]() ![]() |
eddie, see this link regarding recent experiences with boomslang loom
http://www.defender2.net/forum/topic49174-60.html rgds |
Thanks pme, and there was I thinking the Boomslang loom would be the end of headlight problems...
