Home > For Sale & Wanted > [For Sale] Early 90 LT77 gearbox ans LT230 Transfer
rallysteve
I have an early defender 90 LT77 gearbox and transfer box which are no longer required. Transfer box is a 13D suffix with the additional filler port on the top of the input housing. Looks in good condition internally from removing the PTO cover.
Gearbox is a 'longstick' version. Unknown condition. I have run it up in all gears which seem fine but i have not driven with it except 1st and Reverse. Reverse does work but pops out every time you raise the revs.
Gearbox has no wear visible on output shaft splines, nor does the transfer input gear. Gear lever turret, linkage, handbrake mechanism and bellhousing not included.
Both were removed from a 84' 90 (originally 2.5 petrol)
£40 each or 70 for the pair. Collected from Sheffield. 02' 110 TD5 Double Cab Rebuild Thread
Post #596633 27th Jan 2017 6:52am
rallysteve
Bump.... 02' 110 TD5 Double Cab Rebuild Thread
Post #600646 10th Feb 2017 12:31pm
Scott R
England 1985 Defender 90 Other HT Nato Green
Have you still got them for sale?? Rolling Eyes
Post #607234 6th Mar 2017 2:03pm
rallysteve
Hi Scott,
Yes still have the gearbox and transfer box.
Cheers,
Post #607236 6th Mar 2017 2:12pm
Miggit
Hi, I'm interested in the transfer box if it's still up for grabs.. I'd have pm'd you but I'm new to here Sad Just a few to go Rolling Eyes RRC 2.4 TD... it's either a stretched 90 or shrunken 110!!
ML 270CDI
Post #608293 10th Mar 2017 12:45am
rallysteve
Have had a couple of people express interest but both are currently still available.
Cheers,
Post #608382 10th Mar 2017 2:05pm
Miggit
You have a pm Thumbs Up RRC 2.4 TD... it's either a stretched 90 or shrunken 110!!
ML 270CDI
Post #608448 10th Mar 2017 6:27pm
Miggit
Mate I sent you a message yesterday at 18:00 hrs and I still have not had a reply.... and further to that you were on here this afternoon......... Please Look at your messages and answer mine, otherwise I suspect that you will never sell your gearboxes if no one can get hold of you. RRC 2.4 TD... it's either a stretched 90 or shrunken 110!!
ML 270CDI
Post #608691 11th Mar 2017 6:04pm
