Home > Technical > Bulkhead/Windscreen Bracket
mse
I know its a common affliction - but serious the car is only 16 months old and ive noticed the corrosion setting in! Shocked
the $64000 get the gore replacements or get the dealer to fix it (or both!)
its got to go back for some normal warranty paint work anyway - in fact the thing keeps going in for paint defects! Mike
Post #608394 10th Mar 2017 4:34pm
Paul55
England 2008 Defender 90 Puma 2.4 XS CSW Santorini Black
Personally dealer first after all it's under warranty plus it saves you £90 and it gives you another 20 mths to save up for some Gore ones Very Happy Cogito ergo sum
Post #608410 10th Mar 2017 5:49pm
mse
Good point
Just seems like the dealer is only able to make the problems worse Big Cry but your right Mike
Post #608417 10th Mar 2017 5:58pm
Balvaig
Dealer fixed mine twice on previous Defender under warranty. Lasted 18 months each time. New car also showing signs at 18 months. Going to fix it myself and see if I can do better! However no other paint warranty jobs so far.
As you have corrosion I would let the dealer fix it.
Post #608418 10th Mar 2017 6:01pm
zsd-puma
I'd have the dealer do it. Go all over the car in great detail and note down any other little bits that are starting, around the alpine windows for example, and pull back the front door seals just behind the top door hing and see if there is any, get it all sorted at the same time.
Post #608426 10th Mar 2017 6:25pm
mse
Thanks - its been in for about 4 months total just for body shop work its already booked in for more...hence i cant be bothered, but it looks like i will.
From what i understand, the dealers body shop has to follow JLR instructions to repair which arent how a body shop would repair it - which is why have got a spare set of hinges and needing a 3rd set Mike
Post #608434 10th Mar 2017 6:58pm
LR90XS2011
when fixed wipe over with ACF50 repeat ever 6 months wont happen again DEFENDER 90 TDCI XS,
Post #608437 10th Mar 2017 7:09pm
mse
Thanks...i have been doing that and i have FCX (which is better)no joy Mike
Post #608439 10th Mar 2017 7:10pm
zsd-puma
I would try complaining to JLR customer services directly, telling them the bodyshop say they can provide a permanent fix but JLR's procedures wont allow any more than a temp fix, you'll probably get a standard response along the lines of "our procedures ensure a factory finish etc..." when that happens escalate it. I think there's a chance you'll be able to get them to agree to pay the body shop and let them do it properly.
Post #608444 10th Mar 2017 7:18pm
mse
been there and its "it can keep going back until its done right" the problem is, say for the hinges, they arent allowed to fix the material quality so the originals we fine and all the replacements are bad. Mike
Post #608445 10th Mar 2017 7:22pm
zsd-puma
Well the body shop can't change the material quality, all they can do is change the way the paint them, ie the types of primers etc that LR specify.
If you wanted to you could probably buy billet ones and get the bodyshop to spray them under the warranty, they can then just put down that they refinished the original ones rather than replace. It really depends how cooperative the dealer body shop wants to be.
Post #608450 10th Mar 2017 7:30pm
mse
I have a really good dealer...what they need to do is prime, fill sand and paint and they arent allowed to do that by JLR! Mike
Post #608457 10th Mar 2017 7:52pm
Balvaig
Just replaced my window /bulkhead blocks. Interesting findings:
Blocks 18 months old since new. Treated from new with wax polish.
No apparent corrosion on bolts or screw threads.
Problem seems to be the way they are painted. There is no paint or top coat on backs of blocks. This means that if any slight damage occurs at point of contact with gasket, then water gets in and corrosion occurs.
They seem doomed to fail due to the manufacture/paint process, with little or no evidence of dissimilar metal reactions. The goo round the threads in the photo is the glue used to fix the gasket to the block.
Post #609429 14th Mar 2017 5:57pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
I've fitted a pair of these, simply paint and stick them on.
Been on for a few years now and no issues.
http://m.ebay.co.uk/itm/172255282269?_mwBanner=1 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #609432 14th Mar 2017 6:29pm
mse
Very interesting, Seems the same as mine... Mike
Post #609507 14th Mar 2017 10:37pm
