Home > Td5 > TD5 Turbo Actuator Pipe
Tank
Scotland 2004 Defender 90 Td5 HT Zermatt Silver
Does anyone know the code or part number for the TD5 turbo actuator pipe, the 8mm or 10mm pipe that goes to the actuator. Mine is split, old and tired and I need a new one.
Help!
Can get access to the Russian parts catalog, link doesn't work !
http://lrparts.ru/
Tank
Post #608282 10th Mar 2017 12:47am
miker
http://new.lrcat.com/#!/1228/13789/17286/1358/17612
Although that looks like it has the control solenoid of the discovery?
Silicon replacement may be an option?
Post #608286 10th Mar 2017 1:06am
Tank
Thanks Miker
A silicone one would be nice, wonder where I could get a blue one Smile
Post #608290 10th Mar 2017 1:18am
geobloke
Hi.
Mine melted on the turbo whilst travelling through Spain. Quite the task to find a replacement in the middle of nowhere back country.. Good fun Whistle
You can replace this pipe with a length of fuel pipe. It is always strengthened and works a treat plus you can get it from any motor factors. Couple of small jubilee clips and you are good to go.
Post #608301 10th Mar 2017 7:43am
Tank
Thanks guy.
Tank
Post #608303 10th Mar 2017 7:51am
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
Tank,
I have recently replaced the pipe on my dads Td5 Discovery and it is just 4mm internal diameter pipe just do a search on ebay for 4mm silicone and loads come up in all different colours.
Will 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #608361 10th Mar 2017 1:34pm
geobloke
Just make sure the pipe is strengthened internally (laminated) if not you risk collapse or over inflation when on boost... Shocked
Post #608385 10th Mar 2017 3:35pm
bankz5152
Its an actuator pipe. Not a boost pipe.
Post #609118 13th Mar 2017 11:52am
