Home > Technical > Safety Devices 4 Point Internal Cage Install Experience?
Page 2 of 2 <12
big110
 2014 Defender 110 Puma 2.2 SW Keswick Green
Ugggg. horror stories on both SG and PP. I dont have a fitter in mind here so was really wanting to try to fit myself....but having second thoughts now.
congrats, mazol tov, kudos etc etc to those that were able to do it without a pro fitting it! Bow down
Post #607848 8th Mar 2017 3:57pm
agentmulder
Kuwait
ah, I'm just having a moan..
It was recent, so I am still sore. I'm sure that if this thread turned up in three weeks I'd be all 'yeah go for it!'
It wasn't a horror at all, just time consuming.
Thumbs Up Solved the bowel problem, working on the consonants...
Post #607917 8th Mar 2017 8:06pm
big110
well thx for the info. I guess I will order one up. We just have a lack of mechanics and shops where I am located in the woods- no rover machanics that would help with the install or even know where to begin
Post #607977 8th Mar 2017 10:16pm
jst
i fitted a SD soft top 6 point setup to my 90, it was pretty straight forward and all went as per instructions. easy to do yes. just time consuming.
as an aside i had a North Off Road truck cab cage supplied and fitted by Shaun (before he sold the business) for £780 and its the best cage i have had! that was 10 years ago.
i would try North, well worth the call. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #607986 8th Mar 2017 10:30pm
I built the cage up and drilled the wing holes whilst it was on. I struggle to trust templates.
Or to be more precise, I struggle to trust all Defenders are the same size. QRZ 2e0vpf
Post #608025 8th Mar 2017 11:58pm
agentmulder
Kuwait
In my case it wasn't the frame that didn't match but the internal leg that joins to the chassis, it was just a non-starter, I cant imagine there being any way with 'better' manufacturing that it could mate with the template hole as given.
Actually, hrrrm, unless maybe the puma is different? Solved the bowel problem, working on the consonants...
Post #608032 9th Mar 2017 12:13am
Page 2 of 2 <12
