Home > Maintenance & Modifications > washer jet upgrade... any thoughts...
Page 3 of 4 <1234>
JOHNT01670
United Kingdom 2006 Defender 90 Td5 SW Zermatt Silver
The jets looked to be part of the wiper body so unless the rubbers could be swapped I assume a new unit would be required.... 2006 TD5
2002 Honda Transalp 650
1995 Yamaha Vmax 1200
2014 Nissan Juke (wifes)
Post #606052 2nd Mar 2017 2:13pm
huffhuff
United Kingdom 2001 Defender 90 Td5 HT Java Black
Exactly what I thought. Seems an expensive way to buy new wiper blades! TD5 Defender 90
Discovery 3 HSE
Post #606082 2nd Mar 2017 4:03pm
Just fit twin jets and then you are good to go with what ever wipers you want.
I haven't done this yet myself though. _\Hennessey|Venom| F5/___
___\â­ï¸Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°*\\_
Post #606103 2nd Mar 2017 6:04pm
BuckBlu110
United Kingdom 1994 Defender 110 BMW M57 3.0 Diesel CSW Buckingham Blue
On my set up, the jets are clipped on to the wiper arm, so any blades can be used.
Post #606112 2nd Mar 2017 6:40pm
5 POT
United Kingdom 2005 Defender 110 Td5 SW Java Black
On a similar idea has anyone tried heatshot?
http://www.heatshot.com/uk/
Fancy doing this on the Defender to get rid of flies in the summer with near vertical windscreen!
Post #606118 2nd Mar 2017 6:52pm
huffhuff
Just fitted these to mine http://www.ebay.co.uk/itm/201661218144?_tr...EBIDX%3AIT
Only took about an 40 minutes from start to finish with a bit of Censored about. I left the central jet in place and fished the pipes through the other grommets (opening my flaps and going through the ashtray hole with some fiddling). However, the place I went to only had PVC pipe so it's not as flexible as rubber hose. It kinks a bit easier. I also used the existing grommets and just made a hole in them - not great and with the movement they pop out so need some better ones so no (less) water ingress. Water spread is good and pressure ok Smile
If I ever take out the dash, i'll fit the nice double jet setup as it looks more OEM. TD5 Defender 90
Discovery 3 HSE
Post #607530 7th Mar 2017 3:00pm
Lancerdoc999
has anyone tried fitting bonnet mounting spray nozzles? My wife's 1 series BMW has great spreader nozzles that coat the windscreen better than a single jet. Wondered if this might be a good mod to do. They also have a heater element built in which I assume could be wired up with the windscreen or mirrors if you have them. Would have to work out best place to fit and angle of spray including when driving at some speed. Personally don't like the look of those pipes coming out of the bulkhead and they would surely freeze in the winter.
Post #608759 11th Mar 2017 10:41pm
L110CDL
^ ^ ^ I dont know what jet nozzles he uses but grafty99 has fitted some to his bonnet, you can ask him Thumbs Up Clayton.
Keeper.
Post #608769 11th Mar 2017 11:12pm
geobloke
Funny you should mention this, I pulled out a set of Disco3 heated washers from the spares rack last weekend... Thought to me self... Huh... That'd be cool on the 110. These are the jet versions rather than the spread type of the later disco3s. Look to have a good range of angle they can work through. Figure you might be able to fit them to the slope at the back of the bonnet to direct them a tad... Not sure...
Post #608842 12th Mar 2017 12:21pm
Lancerdoc999
Thats what I thought also. The sloped angle might tuck them neatly away and still allow the spray to hit the window fine. I just ordered a set of used heated BMW jets with pipes and wires attached for £20 to see if this might be feasible. What do the disco jets look like?
Post #609012 12th Mar 2017 10:40pm
grafty99
I do indeed have two washer jets on my bonnet. I'll get a picture when it's light.
I have 2 twin nozzle jets and any speed over around 40 mph they SOAK the whole screen just like the VW/BMW ones do when stationary. When below 40 mph they spray nicely in the wiped area Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #609020 12th Mar 2017 10:57pm
grafty99
Here is my setup Thumbs Up
1990 Vogue SE
Post #609085 13th Mar 2017 9:21am
Lancerdoc999
Assume the result is better than a single or double washer setup on the bulkhead?
Post #609257 14th Mar 2017 12:13am
grafty99
It is. I have tried both. This is definately the best for actually getting the screen wet Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #609259 14th Mar 2017 12:18am
geobloke
Like this;
Twin Jets rather than fan spray.
Post #609316 14th Mar 2017 10:18am
Page 3 of 4 <1234>
