![]() | Home > Maintenance & Modifications > how to remove a steering wheel? |
First step put the nut back ON.
Leave it loose by about two turns. Use some penetrating oil. Tap the wheel upwards top, bottom, left right. Do it without nut on expect to get the steering wheel in your face if it comes off suddenly. Brendan |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7932 ![]() ![]() ![]() |
I read the advice to loosen the nut but leave it on (so not to smack yourself in the face) the two feet on the floor and full like ¥$€#, it worked for me. Good luck
![]() MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
tyrannosauROSS Member Since: 24 Jun 2016 Location: Kent Posts: 136 ![]() ![]() ![]() |
thanks chaps....
currently soaking in wd40. ill report back. ross |
RoddyK05 Member Since: 08 Apr 2015 Location: Inverclyde Posts: 633 ![]() ![]() ![]() |
I had to borrow a bearing puller to get mine off. After that I cleaned up the splines and put a little copperease on it to make it easier the next time. It was very slightly easier the second time, but still incredibly tight. Maybe mines was just a super good fit.
![]() Click image to enlarge ![]() Click image to enlarge |
Well done, success indeed. I have the same set up, I see you didn't use the carbon centre ring with your new wheel. I wasn't going to bother either, but the wife thought it looked better with it, so I was over ruled. Like the look of yours though.
For me... the carbon was a bit flashy.
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1789 ![]() ![]() ![]() |
Possibly the only tight fitting splined interface found anywhere on a defender! |
300TDi CSW Phil Member Since: 03 Apr 2016 Location: Bracknell Posts: 857 ![]() ![]() ![]() |
All the splined connections from the steering wheel to the bottom end of the steering box are tight.... don't ask me how I know
![]() Wide Track Sankey- In bits- Gone to a new home M0XQS |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17939 ![]() ![]() ![]() |
It isn't the splines that make it tight, it is the taper behind them. Coupled of course with the fact that many people tighten the nut absurdly tight, for some reason! ("Oh, it's the steering wheel, it might come off! Better do the nut up as tight as I can!")
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 877 ![]() ![]() ![]() |
Same set up as me, I too left the carbon ring off
![]() I also machined off the "Optimill" engraving for a cleaner look...... |
