![]() | Home > Maintenance & Modifications > SVX Fire & Ice Style Steps |
| Paul55 Member Since: 03 Feb 2009 Location: Somewhere in my head! Posts: 514
There's some on LRI Solutions, £210, SVX Style,
https://www.lrisolutions.co.uk/index.php/p...r.html?p=2 Cogito ergo sum |
| adeparko Member Since: 13 Feb 2015 Location: West Lothian Posts: 41
Yeah, seen them when doing my searches
My worry is I don't know what they are made of? Will they be prone to rust compared to the Masai galvanised ones? Anyone got them fitted? Thanks |
| JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7946
Giving my late 2012 110 a decent clean at the weekend and seeing the terrible state of the bumper, side rail steps and the bumperettes (I fitted), I've decided I'm not going to bolt anything else on externally unless galvanised or stainless steel and then powder coated. Everything seems to just rot/corrode so quick
| leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8584
Masai states that the steps are zinc galvanised.
There are two main methods of depositing zinc on to mild steel for protection Electro plating or zinc plating which is the cheaper method and uses an electrical current to deposit the zinc onto the mild steel a coating typically 5-30 microns Hot dipped galvanisation is a process where the object is dipped into a molten bath of zinc and coats the object with 10 times the thickness of zinc that electro plating does. 50-150 micron thickness. The R + T sliders have to have holes drilled in them and zinc coats the inside of the R + T sliders in this process. Hot dipped galv can self heal to a certain extent. Black powder coating on top of hot dipped galv has an orange peel surface appearance. I would guess that Masai are referring to electro plating or zinc plating when they use the expression zinc galvanisation as galvanisation is zinc being deposited on steel. If you do not want your 90 steps to rust then consider the stainless steel steps from Nakatanenga here Just come across this little 'fact'
Brendan |
| zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720
If you have a local galvanisers and powder coaters then it wouldn't be too difficult to get some cheap ones and remove the plastic/rubber bits then have them coated.
The problem is with most of them the coating on them is very poor, even decent quality powder coating would make them last better. Then spray the insides with cavity wax. |
