Home > Camping, Caravanning and Holidays > Vehicle mounted compressor
Keith5
United Kingdom 2012 Defender 110 Puma 2.2 USW Santorini Black
I've had a quick search but struggled to find a relevant thread. I'm considering fitting an air compressor in my 110 to be available for service air (tyre inflation) and inflating an air beam tent.
I'm looking at something like the high output 12v ARB CKMA12.
Does anyone have experience of using one of these to inflate an airbeam tent?
Does anyone know if this unit can be mounted somewhere in the engine bay/inside the front wing? And then having the outlet available through something like the GMB fender locker
Thanks in advance. Keith
Post #607179 6th Mar 2017 11:06am
JOW240725
Can't help I'm afraid but will be watching with interest. Thumbs Up James
Instagram @suffolk_rovers
Post #607191 6th Mar 2017 12:02pm
RoadForce
Netherlands 2000 Defender 130 Td5 HCPU Coniston Green
Don't know if that one will fit, but I have seen compressors fitted in the battery box under the seat. Defender 130 HCPU Td5 MY2000
Post #608134 9th Mar 2017 2:10pm
chopcat
Wales 2000 Defender 90 Td5 CSW Java Black
Post #608183 9th Mar 2017 6:33pm
jst
i fitted a tmax single piston head, under the drivers seat (2.4 Puma) is 150psi, £37, and runs for long periods no problem.
in my case it feeds a GP manifold that then feeds a PCL fitting, on board air tank (9L), lockers front and rear. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #608242 9th Mar 2017 10:16pm
agentmulder
Kuwait
I have this model in my 110 for tyres and camping just as you suggest Thumbs Up
Internet told me to put it in the engine bay in the wing area in front of the aircon, which turned out to a right pain in the bum access wise. Instead I mounted it right next to the battery itself, holes were drilled to both mount it and run control cables to the dash.
This:
- Avoids the issue of overheating being close to the engine in summer (when you're camping!).
- Keeps it clean.
- Means you'd have to run airlines from internal to external for any lockers (if you were to go down that route).
- The passenger get a vibrating seat option, or as the nephews like to call it, "The fart button".
- The passenger, when you actually want to use the compressor, has to be sitting in the back.
Lots of solutions and variations, as it's designed to fit almost all orientations and outlet angles, and when I installed my roll cage I could have easily got the compressor in the wing area at the same time - but hey, it works for me at the moment...
It's a nice unit, seems well put together.
Not sure of the air requirements of your tent, but the duty cycle and heat limit of any compressor needs to be taken into account.
Four tyres from low pressure/sand to road ready is about its limit (specifically designed that way). But I doubt your tent will mean it's fighting pressures like tyres, but it will still be pushing air for a while and might need a rest to cool down in the middle. Solved the bowel problem, working on the consonants...
Post #608271 9th Mar 2017 11:26pm
jst
If.you run fittings direct off the compressor use proper heat resistant pipe.
I run mine to pcl fitting on seat box so don't have to take seat out. Its 8mm feed from pump head which I screwed a barb fitting into. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #608310 10th Mar 2017 8:43am
Keith5
Agent Mulder, which one did you fit? One of the TMAX ones?
I have a twin battery setup under the passenger seat so would be too tight on space, also have the relays and aux fuse board under the drivers seat. In terms of space to fit I'm looking at engine bay/inside wing as I don't really want to start fitting rear wing lockers yet. Keith
Post #608319 10th Mar 2017 9:59am
jst
Keith what vehicle is it?
under rear seat in 110? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #608327 10th Mar 2017 10:41am
Keith5
JST - a 110USW
Are you meaning an install in the space underneath the folding rear seats or slung under the seatbox? Keith
Post #608331 10th Mar 2017 11:01am
agentmulder
Kuwait
I have the compressor you mentioned (ARB CKMA12), I could have gone under the drivers seat but I have an inverter in there already. The inverter is larger than the compressor, give it a try Thumbs Up
If you're going under the aircon, take off the plastic wheel arch and you should be able to get an arm up from the other direction - may prove helpful Wink
Taking the wing fully off is a right pain in the exhaust though:
Post #608336 10th Mar 2017 11:15am
chopcat
chopcat wrote:
I have fitted one for a pump up http://www.chopcat.co.uk/page1/blog/files/...stuff.html
TC
sorry you had to drill down a bit on the blog
Post #608362 10th Mar 2017 1:35pm
Keith5
Following some recommendations I'm leaning toward fitting it in a barebox on top of one of the wheel arches.
Been advised to fit some sound deadening and pick up the existing 12v supply that runs to my inverter in that area to minimise the install hassle. It should also give me somewhere to store the accessories and other tools safely. Keith
Post #611166 21st Mar 2017 5:44pm
agentmulder
Kuwait
Not sure how critical it is, nor how much you planned on using it 'non-stop', but keep in mind that sound deadening could be a problem in terms of thermal insulation... Solved the bowel problem, working on the consonants...
Post #611217 21st Mar 2017 9:40pm
Keith5
That's a good point.
The plan was to use it to inflate tyres and camping accessories so would be used when parked up with the lid of the barebox open to get the line out. Keith
Post #611287 21st Mar 2017 11:59pm
