Home > Td5 > performance issues!
monk
United Kingdom 2000 Defender 110 Td5 DCPU Java Black (black Hood)
performance issues!
Hi hope someine can help, td5 110 2000, fitted rev counter yesterday along with slickshift, rev counter on the lazy side, just so i could see what revs im doing in 5th, 10 psi 5th gear approx 55-60mph (running 20" range rover wheels so speedo over reads) anyhow reaches this speed nicely no drama but put foot to the floor sounds and feels like its going to blow! Plus struggles upto 65-70mph, new injector harness dry ecu plug, cleaned airbox/maf/intake sensors, new air/fuel filter/pump,propshafts ,egr delete manual boost control with gauge running17-18psi, wastgate free, tried unplugging maf with no difference, plus cant see any leaks from fpr, i know i need to get it on diagnostics but nobody really local who wont charge arm n a leg n probably no more idea then to change more stuff!
Heeeeeelp pleeeeease!
Post #606920 5th Mar 2017 3:20pm
What size tyres are fitted to your 20 inch wheels?
What do you mean by 'feels like it's going to blow'? Darren
Post #606943 5th Mar 2017 5:12pm
geobloke
20" rims, eeshk more rim than tyre on those bad boys...
Looking at your list you do not mention whether you have had an ECU remap. If you have not, this is your likely problem. All wind and no go... As in you have raised the boost pressure but not the fuelling to match. Also notice you do not mention an uprated intercooler, definitely worth the price for the extra performance it will add.
If you were this direction (wales) you'd be welcome to plug it in to the nanocom. Stick a Help request up, I am sure there must be a dozen folks Yorkshire way with diagnostics equipment.
Post #606945 5th Mar 2017 5:14pm
monk
Cheers for the reply lads, im unsure on tyres at the minute laid up after 8 injections in my back few days ago albeit rev counter n slickshift got fitted in the dark as was bored out of my skull! Well i did try boost at 14-15psi and no difference in the problem, slight higher boost gives a little more kick ,wanting to get a rechip asap but wanted to solve this problem first , ive an uprated intercooler all alloy think same size slightly thicker core, its really annoying me ,apart from headlight troubles grrrrr it runs nice!
Post #607022 5th Mar 2017 7:58pm
monk
Oh and cheers for the diagnostics offer mate, yeah bit far to drive especially when im stuck driving at 50 Banging Head
Post #607025 5th Mar 2017 8:01pm
roel
I don't understand what you are trying to say. So I can't give any advise. Roel
2003 90 Td5 (2009-now)
Post #607028 5th Mar 2017 8:22pm
monk
Truck struggles to rev past 2500 rpm showing 10psi boost and 55mph, driving is fine if driven casualy but try putting foot to floor it sounds and vibrates like an engine was past its rev limit after 55 ish
Post #607034 5th Mar 2017 8:45pm
mk1collector
When you switch the engine off do you get a sort of chirp noise as it stops? Ray
My build thread
Post #607042 5th Mar 2017 8:57pm
monk
Hi mk1, actually just looked through 40 odd pages of your posts on your truck on my phoneheadache now! very nice by the way! Our lass would kill me if she new what i spend, canr stop so addictive! Mainly bought it to modify make parts myself as into building bikes, As for a chirp/noise not that i recall but ill listen for it, what with or without this noise could that be? Cheers
Post #607055 5th Mar 2017 9:20pm
mk1collector
Thumbs Up thankyou, the chirp could suggest the lower pulley rubber is degrading. I had this on mine which caused a bad vibration at higher revs and speeds Ray
My build thread
Post #607069 5th Mar 2017 9:42pm
monk
When you say lower pulley rubber, would that be the tensioner? Ive just replaced the bearings on the other two runners and belt after the (other new belt) id had put on caused bearing to destroy itself, its in for its first mot from me owning it! Hoping they find some simple solutions ! The truck looked nice when i bought it turns out everything had been bodged and not in a long lasting way making somethings harder to sort out, cheers
Post #607074 5th Mar 2017 9:59pm
mk1collector
The crank pulley has/is a rubber harmonic damper and the rubber on mine had deteriorated causing a big vibration at higher speeds. Give this a read on the disco 2 site.
http://www.discovery2.co.uk/CrankPulley.html Ray
My build thread
Post #607112 5th Mar 2017 11:28pm
roel
If you put your foot down, does the turbo presure increase very quickly or not at all? Roel
Post #607116 5th Mar 2017 11:38pm
monk
Hey mk1 thanks il have a nosey around that rubber tomorrow, wouldnt let me open the videos for some reason, roel yes turbo boost pressure is fine, pulls well!
Post #607123 5th Mar 2017 11:53pm
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
Boost pressure does not have a specific setting for a set RPM it all depends on throttle position, load etc so you could be doing 50mph on a flat road and have 10 psi of boost or 50mph going uphill laden and have 18psi depending what the waste gate is set at.
What gearing does it have? If you have big wheels and tyres, and previous owner has fitted discovery gearing it might be too over geared.
Will 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #607314 6th Mar 2017 8:47pm
