Home > Puma (Tdci) > Towbar and electrics for Puma
Page 2 of 2 <12
zsd-puma
i'll try and remember to do it tomorrow.
Post #606151 2nd Mar 2017 8:35pm
Rallymental
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Santorini Black
Thumbs Up thank you
Post #606226 2nd Mar 2017 10:29pm
zsd-puma wrote:
Just use an alko ball and wipe the grease off with brake cleaner when you want to use it with a stabilised hitch. Wink
Very true, but if you've got the kit then why ignore one of its' big benefits? Wink To be honest, I prefer different tow balls even with a bolt on solution. The Alko pads are too easily contaminated.
zsd-puma wrote:
It's worth remembering small box trailers usually sit very nose down until you load them up and compress the trailer suspension.
In my experience, the suspension on small trailers don't compress that much, but it's academic anyway, as in my case it was already nose up on our regular caravan hitch setting. Darren
Post #606340 3rd Mar 2017 11:08am
Rallymental
Darren, which setting do you have the ball on for towing the caravan?
I never had a specific alko ball with my old 'van isn't it just narrower at the bottom?
Post #606351 3rd Mar 2017 11:33am
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
Rallymental wrote:
I was looking at the Dixon bate sliding adjustable towbar. I'm thinking there's more adjustment than with the LR one?
If you are looking at the adjustable hitch go for the larger slider as they offer more adjustment and have two pins although you can purchase extra pins for the small slider. As has been said the smaller one does rattle with a single pin and the trailer pitches up and down even though it s small amount you can feel it and hear it. Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #606358 3rd Mar 2017 11:57am
I can't remember, if I'm honest, as it was two Land Rovers ago and we now use a D4 for towing it. It's van-specific though, so may be different for you anyway. Ours is a twin axle and so is towed slightly more level than single axle ones, which means the hitch benefits from being slightly higher. Darren
Post #606364 3rd Mar 2017 12:12pm
Rallymental
i wonder why they don't sell the whole kit in either one pin or two pin versions?
Post #606432 3rd Mar 2017 3:26pm
Dunno. The kit as it stands has been around since '98 and in slightly different versions since long before then. Two pin sliders are relatively recent by comparison. Perhaps it's just not a big enough volume seller to warrant changing the kit. Darren
Post #606443 3rd Mar 2017 4:08pm
Rallymental
Thank you all for your thoughts and advice Thumbs Up
I'll let you know what happens next!
Post #606568 3rd Mar 2017 11:36pm
zsd-puma
Finally remembered to do this.
In the middle holes on the tow bracket - from the ground to the centre of my tow ball is 530mm.
I can move the towball up or down by one set of holes, which would give a difference of about 45mm up or 45mm down.
Bear in mind i have a pin and ball type hitch, which does make the ball sit slightly higher than a plain tow ball.
Ifor Williams specify a towball height of between 485 and 535mm, so the bottom and middle holes are more or less spot on for that range.
Here's quite a good explainer for recommended tow ball heights.
https://www.pfjones.co.uk/towball-heights.html
Post #609178 13th Mar 2017 7:57pm
Rallymental
Cheers Thumbs Up The definition of insanity is doing the same thing over and over again but expecting different results.
Solihull, 1948 - "If we paint the chassis, it will last for years"
Solihull, 2015 - "If we paint the chassis.............................
Post #609197 13th Mar 2017 8:37pm
Rallymental
Ok, I've picked up the tow bar kit, I went for the Dixon Bate adjustable in the end, I got it from Island 4x4 in Maidstone �99 +vat and the electrics kit is on its way from PF Jones �89 all in including postage.
So now the question is does anyone have any tips or observations for fitting it?
I'm thinking of a liberal dose of acf50 but would you smear something between the surfaces to keep the water out? The definition of insanity is doing the same thing over and over again but expecting different results.
Post #610767 19th Mar 2017 11:52pm
zsd-puma
Grease, dinitrol or waxoyl between the surfaces will do. You can download the Land Rover fitting instructions from topix. But it's all pretty easy.
Island 4x4, great unless you need to return something or get in touch with them - then it's a total nightmare.
Post #610776 20th Mar 2017 12:20am
Page 2 of 2 <12
