Home > Puma (Tdci) > Engine/tranmission mounting
Rocket123
United Kingdom 2008 Defender 110 Puma 2.4 XS DCPU Epsom Green
Can anyone advise if this is correct? It doesn't seem to be connected to the cross member
Thanks
Rocket
Post #6042 7th Jan 2009 9:53pm
The Boy
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Rimini Red
Yes mate mine is the same but like you when I first got mine i thought the same.
Post #6043 7th Jan 2009 9:59pm
Bosun
2008 Defender 90 Puma 2.4 XS CSW Tonga Green
Apparently there's not supposed to be any kind of bush or isolator in between. On mine, the two holes don't line up very well anyway.
Post #6051 8th Jan 2009 8:38am
mrwoo
United Kingdom 2004 Defender 90 Td5 CSW Epsom Green
Mines the same, not caused any problems in the last 29k
Post #6052 8th Jan 2009 9:00am
Eduardo
Mine is the same.
So, appears to be an unused part or something to keep the piece in place during mounting.
Cheers Eduardo
Post #6060 8th Jan 2009 12:56pm
dm_td5
Australia 2008 Defender 110 Puma 2.4 SW Zermatt Silver
Same here. When I first saw it I wondered what it could be for too.
I'd be worried if the holes did line up perfectly... after all it is a Defender!
Perhaps that's its use. Its a quality control check for misalignment Rolling Eyes 110 2.4TDCi
110 300Tdi
LROCV ::: AULRO.com
Post #6061 8th Jan 2009 1:02pm
AndrewS
I think its as described above. There is an optical laser measuring device at the end of the production line. If the two holes line up the test driver Censored one of the front wheels into a 9" curb at 25mph. This then miss aligns the vehicle which in turn causes component failure Thumbs Up Thus keeping suppliers and dealers busy during these hard times.
Post #6072 8th Jan 2009 8:45pm
The Boy
Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter
Post #6075 8th Jan 2009 8:58pm
Grockle
This has been bought on afew sites it should not be boleted to anything. 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #6086 9th Jan 2009 10:34am
