Home > In Car Electronics > Concealing a iphone charger lead
datcullen
2015 Defender 110 Puma 2.2 USW Java Black
I think I've read that a few people have fitted an iphone charger lead into their after-market puma glovebox.
I'd like to do similar to avoid my knuckles rapping the usb end when changing gear. How have people wired up the USB end? I was looking to see if there was a rear USB on the CDE 133bt but from what I can find it is a front USB only...?
Thanks all,
Beau 110 UW - '15 2.2
90 - '85 V8 soft-top
RRC - '84 5 door, Option Pack C, 33k miles from new
Elise S1 - '00 Millennium SE
Elan +2 - '68 kit built by my dad
Panda 4x4 - '87 in Italy
Post #605243 27th Feb 2017 1:50pm
Not all units have rear exit USB, it varies on model.
Were you wanting it to be connected wired to the HU or purely for charging purposes? ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #605246 27th Feb 2017 1:53pm
datcullen
Thanks Steve.
Main aim is for charging purposes - at the moment I've got the USB end plugged into an adapter in the 12v socket and keep bashing it when shifting into 5th (possibly due to my innate clumsiness). Plus it would look neater if hidden.
Thumbs Up 110 UW - '15 2.2
Post #605261 27th Feb 2017 2:39pm
LR90XS2011
there are a number of mini USB hard wire kits for dash cams that would work perfectly if your need is mini USB GOOGLE dash cam hard wire kit DEFENDER 90 TDCI XS,
Post #605301 27th Feb 2017 6:59pm
datcullen
Thanks LR90 but I need it to end in an Apple Lightning connector to charge an iPhone 6.
Unless I've misunderstood you! 110 UW - '15 2.2
Post #605331 27th Feb 2017 8:49pm
Use a hardwired standard USB socket. BlueSea do some good panel mounted solutions. Check out 4x4 overlanders offerings.
Then you can just plug in your normal lighting charging cable to USB.
Lighting male to your phone.
USB male to female USB socket.
You can take your power feed from the lighter socket feeds from behind, they are then ignition switched too so no risk of battery drain.
Just bear in mind there will be a draw on there, regardless of normal use for anything you may use.
You can do this I'd have thought for under £30 max. ____\We|Will|Win/___
Post #605375 27th Feb 2017 10:15pm
mick
I went this route the lead comes from back of the radio
Post #605378 27th Feb 2017 10:22pm
^^^^ That is the best solution, from the rear of the HU if available. ____\We|Will|Win/___
Post #605381 27th Feb 2017 10:25pm
mick
Works a treat
Post #605382 27th Feb 2017 10:27pm
Is that another cable in the background?
You can take feeds from the rear of the dash Dow to under carpet / matting just either side of the trans tunnel. There is a nice void just to the upper side to the left of the clutch on the Puma for plenty of stuff too.
Some people remove the lighter socket sad fit twin USB sockets in there too. ____\We|Will|Win/___
Post #605403 27th Feb 2017 11:11pm
mick
No it's the iPod cable it wasn't plugged in
Post #605414 27th Feb 2017 11:20pm
