Home > In Car Electronics > Ferrite Rings
Bushpig
Wales 2012 Defender 110 Puma 2.2 SW Alpine White
Ferrite Rings
I've managed to finally get hold of some ferrite rings to hopefully solve the HID's interfering with the radio reception.
So should the rings go on the power supply at the ballast or where the power supply runs close to the aerial cable?
Presume, that it will end up being a 'trail by error' operation...
Thanks in advance Bow down Human beings, who are almost unique in having the ability to learn from the experience of others, are also remarkable for their apparent disinclination to do so.
Douglas Adams
2012 2.2 Puma
Post #605185 27th Feb 2017 9:11am
Peter Td4
Belgium 2008 Defender 110 Puma 2.4 HCPU Santorini Black
The closer to the source the better; hence any piece of wire will radiate the interfering signal(s).
Doen't hurt to wrap those ferrite rings with some electricians tape to protect them from moisture, some ferrite materials tend to rust after some time when exposed to the elements. Peter,
Defender 110 StaWa - Td5
Defender 110 HCPU - Puma
Defender 90 Soft Top - Td5
Post #605189 27th Feb 2017 9:29am
Clive
United Kingdom 2004 Defender 90 Td5 X-Tech LE Zambezi Silver
The rings need to go as close as possible to the source of the high frequency switching, IE the ballast, this is to absorb the high frequency content and prevent the wires leading into it from acting as an antenna which radiates the interference.
Post #605190 27th Feb 2017 9:31am
Bushpig
Thanks Gents...
Will let you know how I get on, once they arrive...
Thumbs Up Human beings, who are almost unique in having the ability to learn from the experience of others, are also remarkable for their apparent disinclination to do so.
Douglas Adams
2012 2.2 Puma
Post #605264 27th Feb 2017 3:08pm
MadTom
Czech Republic 1999 Defender 130 Td5 HCPU Baltic Blue
And if possible both + and - wire should pass the same one ring. This is to supress the DC current passing through the wires. This current can saturate the ferrite ring, and it will not working correctly to supress the interference.
Standard ferrite ring works good around 100MHz (+-), for much lower frequencies you need a proper filter, fur much higher some additional shielding on cables works better. If you need all frequencies, you hat to combine more types of filtering. "Drobek" = The Small One - Discovery 2, "BlufĂ­nek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #605464 28th Feb 2017 9:02am
explore
United Kingdom 2011 Defender 110 Puma 2.4 DCPU Stornoway Grey
My LED head lights interfered with FM radio, fitted DAB radio solved the problem
Post #605507 28th Feb 2017 1:42pm
Bushpig
The rings finally arrived in the mail... but are now not needed Rolling Eyes
While waiting I replaced the aerial and removed all the quick splice connectors (used by the dealer who fitted the spots) with solder & shrink wrap.
Now there is no interference Whistle Human beings, who are almost unique in having the ability to learn from the experience of others, are also remarkable for their apparent disinclination to do so.
Douglas Adams
2012 2.2 Puma
Post #609111 13th Mar 2017 11:28am
A poor earth connection at the aerial end will often result in massive intereference. My LED lightnar rendered the radio unusuable until I cleaned up the connecteion between the aerial and the wing.
Post #609121 13th Mar 2017 12:14pm
