![]() | Home > Off Topic > Heat shrink cable connectors |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5135 ![]() ![]() ![]() |
If they look like these then yes you crimp then heat up the sleeve, inside is adhesive lined so once heated and shrunk it makes the connector waterproof.
![]() http://www.youtube.com/user/conwy1 |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4316 ![]() ![]() ![]() |
The ones I have, have a solder ring inside, you heat the whole lot up until the solder melts, the glue melts and sleeve shrinks, no crimping. i use a small gas torch for heating it. 2007 110 TDCi Station Wagon XS
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1317 ![]() ![]() ![]() |
Any recommendations for a decent small gas torch?
Having Creme brule for dinner |
ARC99 Member Since: 19 Feb 2013 Location: North Yorkshire Posts: 1831 ![]() ![]() ![]() |
After a bit more research it appears that there are two types, crimp and heat shrink and heat shrink and solder connectors its just a case now of working out which is which. Don't make old people mad.
We don't like being old in the first place, so it doesn't take much to ![]() Richard |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20939 ![]() ![]() |
Yes, this one: http://www.screwfix.com/p/dremel-f0132000j...0wodoCYGeQ ![]() ![]() Those heatshrink connectors, personally I don't like them at all. Better off just soldering and then heatshrink. I oersolly don't like any clear / see though electrical connectors, but that is just me. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Thanks Steve
![]() You would be pleased if you purchased. ![]() ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
They are probably not in at the minute, but I have the Aldi version of that Dremel, I think it was half that price. Have used it loads and it works a treat. TBH even at the Dremel price they are great handy tool. 2007 110 TDCi Station Wagon XS
I already have the Portasol Technic for soldering
![]() Dremel looks good - wish I had got that instead but I have had the Portasol for years and its a great soldering iron. |
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 510 ![]() ![]() ![]() |
Adhesive-Lined Heatshrink Butt Connector and two cables �
![]() Click image to enlarge Strip the ends of the cables to be joined � ![]() Click image to enlarge Insert the stripped cable ends into the Butt Connector from each side � ![]() Click image to enlarge ![]() Click image to enlarge Crimp each cable into the Butt Connector using a suitable Crimping Tool � ![]() Click image to enlarge Finished crimps � ![]() Click image to enlarge Heat the Heatshrink Sleeving until it�s shrunk and the Adhesive flows out � ![]() Click image to enlarge Finished joint � ![]() Click image to enlarge Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
