Home > Maintenance & Modifications > aluminium oxidation
tolley
United Kingdom 2006 Defender 90 Td5 CSW Oslo Blue
aluminium oxidation
any one treated the aluminium corrosion to the doors etc , some have said vinegar solution , before painting .
Post #604610 24th Feb 2017 8:45pm
Are you wanting just to paint?
If not, you are aware you can polish away?
Depends what you want though. WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #604635 24th Feb 2017 10:15pm
tolley
Yes respray.
Post #604642 24th Feb 2017 10:43pm
Ah yes, pretty sure vinegar it is as suggested here.
For some bizarre reason when I posted earlier I thought you meant Alu Chequer plate.
My fault. WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #604643 24th Feb 2017 10:49pm
tolley
is it ok to after washing in vinegar ,then ok to use filler then primer and top coat ,or coat the surface after washing ,with a primer then filler ?.
Post #604691 25th Feb 2017 10:08am
tolley
just done a search on the net , seems the thing to use is Alodine 1201 none as bonderite c-ic33 , but can I find it in the uk Razz Twisted Evil nope .
used a lot on aircrafts to stop, just the same rot as on the landy .
Post #604706 25th Feb 2017 11:40am
I'd opt for primer, filler, epoxy sealer, paint base, clear.
Obviously there is the sanding steps in between, don't use wet and dry wet though with filler as its porous and will take on moisture. Use it dry.
Panel wipe also needed for each step, but I don't panel wipe between base and clear, everything else I do.
I'm sure you know all of this anyway. Thumbs Up
Masking wise there is some nice very cheap polythene dust sheets on eBay for just a couple of quid and some blue 3m masking tape would be helpful too.
After the vinegar just make sure it's panelwiped, Upol 20 fast wipe would be ideal.
Beware of its fumes, use in well ventilated areas. WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #604713 25th Feb 2017 12:02pm
tolley
Many thanks for all the info, Thumbs Up great, goes along with what I was thinking of doing, might try and get some of the aircraft stuff first, but last resort, vinegar it is.
Post #604718 25th Feb 2017 12:28pm
Hope all goes well. Thumbs Up WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #604730 25th Feb 2017 2:03pm
