![]() | Home > Series Land Rovers > Thoughts on this SIIa? |
orkneydave Member Since: 25 Sep 2016 Location: Orkney Islands Posts: 76 ![]() ![]() |
This SIIa has come up for sale locally and I'm quite interested.
![]() ![]() ![]() ![]() I have been given a price but keen to hear everyone's thoughts on it. It's running a 19J engine which apparently is in good order (not running on and no smoke) and the underneath looks good. |
Ramsay Member Since: 30 Sep 2015 Location: Moffat, Dumfries & Galloway Posts: 633 ![]() ![]() ![]() |
It is not a IIA. It looks like it is a Series 3 with a IIA front bolted on. The C reg would suggest the the original identity would be a Series II not a Series IIA.
Did you get the chassis number from the plate on the bulkhead. The first four digits will identify the Series it is. 1995 Defender 110 CSW 1971 SIIA Lightweight |
Thanks. I'd noticed the bulkhead was SIII. When the previous owner bought it, it had a SIII front end which has been changed back to SIIa at the same time as the 19J was put in. I've not seen it personally yet as it's in Leeds but I'm in Orkney
It looks more likely to be a Series II with a III dash fitted ![]() 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
And gearbox, and handbrake and floor and transmission tunnel and windscreen and doors and seats .
It has a IIA steering wheel as it has centre horn push. 1995 Defender 110 CSW 1971 SIIA Lightweight |
scotty38 Member Since: 21 May 2011 Location: Lincolnshire Posts: 571 ![]() ![]() ![]() |
Series 2s ran from 58-61 so if the C plate is legit it's a 2a |
....with a series 3 bulkhead..... |
You might be right. C reg is IIA territory though - 1965 - and without further info it just seems more likely to have been updated with newer bits than back dated.
The headlights moved to the wings in 1969 so if this one is correctly registered as a C reg then the lights are correct as is. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
yep correct. I said "dependent on age" and "if the C reg is legit" etc etc as this determines what it should or shouldn't have. Need to know the chassis number and what price is being asked first though.....
Sorry, I was really replying to Ramsay but you got a couple posts in whilst I was still typing. Darren
110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia Last edited by LandRoverAnorak on 24th Feb 2017 10:28pm. Edited 1 time in total |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17850 ![]() ![]() ![]() |
I'm thinking it may be a SIII which has "assumed" the identity of a IIA perhaps at a time when the III wasn't eligible for Historic VED rates.
Whatever the reason, I'd be very wary with that one, and establish exactly what it is and why it is like it is before considering it. |
Most of it looks like S.IIa rather than S.III. It's probably been 'upgraded'.
There's no heater vent in the wing and the door hinges are S.IIa. ![]() |
Yes, he says it had the s3 front end replaced...
milesr3 Member Since: 12 Feb 2013 Location: Suffolk Posts: 873 ![]() ![]() |
Tub is S3 isn't it with the number plate on the left?
