Home > My Defender > My Defender 90 XS " The Dragon "
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Purchased as an ex-demo with 900 miles on the clock, in August 2010. Have just finished installing all the bits and pieces I received as birthday and Christmas presents. I 've owned 2 series 3 LWB in the distant past when we used to tow a 25' caravan around UK and France and inbetween a number of sports cars from Mitsubishi,Alfa Romeo with the last a RX8 with a rotary engine. Big difference and a lot to get used to but even the wife likes it and she loved the RX8. Have covered 7000 miles since with a lot on motorways cruising at 70 + mph. I do notice that people cruising in the middle or outside lane pull over when they see this bearing down on them in their rear view mirror.
So this is what I've fitted so far:-
Mantex RAI
LED bulbs all-round except for Indicators (working on that). Front Daylight driving lights, 2 x Front X-Light fog lamps. All additional lights run via relays in Battery box. Front Steering Protector and Diff protectors Front & Rear.
Rear X-Light to provide more light when reversing
Reversing sensors inserted in the jacking point on the rear crossmember with audible and visual indicator in cab. Rear Bumperettes. Didn't want to advertise the Dealership that sold me the 90, as they are in Park Lane London and I'm in Wales so decided to rework the Spare Wheel cover. Wet & Dry, Black Vinyl spray paint and a suitable Vinyl decal + Landrover Badge sorted that out.
Heater intake scoop.
Scangauge II on dash fitted via a Y connector to OBD connector so the Dealer still has access to OBD connector. Small LCD screen nearest door is for the Parking sensors - shows distance in Metres.
Fire extinguisher and additional Electrical sockets on rear of cubby box - ignition controlled so I don't leave anything on.
Finally Aero wipers.
Now for some fun.
Post #57119 6th Feb 2011 2:20pm
lrdxb110
United Arab Emirates 2008 Defender 110 Puma 2.4 CSW Stornoway Grey
Nice looking 90 welsh gas Mr. Green where did u get the non slip mat on top of the cubby box? Cheers '08 LR Defender 110
'08 Mini Cooper S - Sidewalk
'86 MB 500 SL
'79 MB 450SEL 6.9
Post #57137 6th Feb 2011 3:22pm
WelshGas
Thanks for the comment. The non-slip mat came of eBay, from outside the UK if I remember correctly. Works well.
Post #57156 6th Feb 2011 4:42pm
WelshGas
Now has LED's in internal lights and the RDX covers for all the rear lights. Cannot decide if I should fit them to the front Indicator/Side lights as well.
Post #60217 20th Feb 2011 6:28pm
Zagato
Very nice, can't fault it - well maybe, your accident assistance sticker ain't straight Laughing Well when you get to this standard you can only nick pick Thumbs Up Oh and those blue rags....really have to be ironed and folded don't they Laughing Defenders do look good in black...........
Post #60220 20th Feb 2011 6:52pm
discocuzzy
I agree, until youve taken it offroad a few times, then all you want to do is cry, shows up the slightest scratches Big Cry You cannot teach stupid people to do clever things
Post #60259 20th Feb 2011 9:54pm
WelshGas
Thanks for the comments. Coming upto its 1st service in March. No problems so far - touch wood - . apart from some water ingress around floor rivets behind seats sorted with underseal along seam and rivets underneath, now dry. Will try and staighten Accident sticker for you Zagato. Undertaking an Off-Road driving course in the Neath Valley in March - Christmas Present from the family. Did the same on my 60th with their own 110 300tdi, now to see how my own Puma does. Thumbs Up
Post #60450 21st Feb 2011 10:05pm
Caterham
great stuff. Thumbs Up
couldn't tell me which front LED lamps you went for to replace the originals could you?
Post #60473 21st Feb 2011 11:47pm
WelshGas
White versions of these:
http://tinyurl.com/632hage
Post #60479 22nd Feb 2011 12:11am
Caterham
WelshGas - thanks for that.
Post #60517 22nd Feb 2011 9:03am
alantd
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
How are the x-lights?
I was looking at them (maybe as my rack-mounted spots) but wasn't sure if they were bright enough. One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition
Post #60679 23rd Feb 2011 1:27am
WelshGas
WEll, they are well made, solid aluminium with the blb/lens is a one piece solid unit. I've got the fog light versions which is a dispersed beam giving as much light as dipped beam ( I've upgraded the headlight bulbs to Halford's Super performance replacements ) but with a wider spread. I've no experience of the spotlight versions. The bulb/lens unit is rated at 55 watts so they are road legal, depending on how/where they are fitted. They are self draining if fitted the correct way up, but mine are upside down so I drilled, easily, a 10mm drain hole so if they get filled they drain easily and have performed well so far.
http://www.x-eng.co.uk/X-Lite.asp?MID=4 Thumbs Up
Post #60685 23rd Feb 2011 7:52am
Kez
Isle Of Man
Hi WelshGas, another South Wales person here, may I ask who fitted the reversing system and assuming you were happy with them how much it cost? Regards, Kez
Post #67395 15th Apr 2011 7:01am
Zagato
What make of bumperettes are they Welshgas?
Post #67400 15th Apr 2011 7:42am
DefenderOfTheEarth
Don't suppose you're from Wales are you? Wink Mr. Green
Lovely truck. Very Happy Defender 110XS SW gone... now VW California 180 4 Motion.
Post #67411 15th Apr 2011 9:58am
