![]() | Home > For Sale & Wanted > [For Sale] HD V8 90 halfshafts |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6202 ![]() ![]() ![]() |
Having a bit of a garage clearout....
Some parts I used to carry years back, when I had drum braked rear axles! and later disc braked disco rear axle. A pair of genuine V8 HD 90 rear shafts along with a pair of the thicker drive flanges The flanges are almost new, hardly any wear in the splines at all. The shafts have a little wear on the flange end (diff ends are like new). I fitted the shafts into the flanges here, and there's minimal play... not "none", but not a lot either. These will fit into a disco/rangie axle if you drill out and tap the flange securing threads to M10 (This is what I used to run on my old 90... think it was done also on the factory camel disco 1's that had the V8 4 pin rear diff fitted) Looking for £50 the lot, or offers. They're pretty heavy so postage might be a killer; Located in Swindon, but PM me if you're interested as I travel around surrounding counties with work. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
pepethekingprawn Member Since: 12 Jan 2016 Location: Lancashire Posts: 54 ![]() ![]() ![]() |
Ridiculously long shot, but are these still available?
Indeed they are sir.
diesel_jim have sent you a pm.
I've had a few replies to these shafts via PM. so I'll answer them in turn.
A couple of folk have asked for postage pricing, which I'll try and get done tomorrow (Saturday), failing that, monday. Naturally first dibs goes to Pepekingprawn, then to Justdefender, then to the other PM's cheers all |
Sold
