![]() | Home > Technical > Torque Wrench |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2509 ![]() ![]() ![]() |
Up to ca. 200 Nm (suspension) Puma 110" SW
pannawonica Member Since: 21 Nov 2010 Location: Clackline Western Australia Posts: 568 ![]() ![]() |
Thanks for the prompt reply.
![]() Now onto the Warren and Brown website ![]() |
You may want to consider a couple of interchangeable driver heads unless ALL your sockets have the same drive whilst you're ordering!
![]() Treat every day as if it is your last....one day you will be right!! |
Yes different driver sizes are a good idea. I am looking at getting 3/8 and 1/2 inch because of the nm range required.
Basically a small and large one. ![]() |
![]() ![]() Treat every day as if it is your last....one day you will be right!! |
