Home > Maintenance & Modifications > Puma Window blocks - Advice please
Balvaig
Hello everyone.
Seeking your wisdom please.
My window blocks seem to last about 2 years before corrosion sets in. Cleaned the car this weekend and there it is again! Third time now on two different Defenders.
Seems more trouble than it is worth to claim on warranty again, ( car in for examination, then one or two days to rectify), so was going to order up OEM blocks and colour match to car myself.
A quick search found black coated anodised aluminium brackets from Famous Four for around £50.
These look similar to the OEM ones and would go with the Black Pack on the car. Saves me the trouble of colour matching too. Smile
Wondered if anyone had experience of aftermarket window blocks and how long they are likely to last before they too corrode.
I would prefer to use window blocks that are near identical to OEM.
Thanks for any information and advice.
Stephen
Post #603295 20th Feb 2017 1:50pm
zsd-puma
I think the standard ones are made from fairly low grade cast ally, and probably not painted all that well by the body shop. The corrosion seems to start from the face where it goes onto the body which is normally left bare. Some grease on it and a paper gasket would help.
Anodised ones are always going to last a a lot longer than painted ones. I've not got experience of anodised windscreen blocks, but my mini has had anodised brake calipers on it since about 2004 and done about 50'000 miles. No obvious corrosion on them after living in road salt, brake dust and the weather with barely any washing.
There is also no reason why you can't paint over the anodising.
Post #603300 20th Feb 2017 2:09pm
I bought a set had them shot blasted and power coated .. 5 yrs on and they are fine, blocks are about £10-15 ea and power coating cost £20 ... not much of a saving
Post #603304 20th Feb 2017 2:31pm
AMBxx
I've just fitted the Gore replacements: http://goreproducts.com/products/defender-windscreen-brackets
My original blocks lasted just over a year. Decided it wasn't worth the time to arrange a warranty repair.
Post #603307 20th Feb 2017 2:33pm
JOW240725
http://www.defender2.net/forum/topic52713.html Whistle James
Instagram @suffolk_rovers
Post #603320 20th Feb 2017 3:35pm
Bristol 90XS
Simple fix and permanent and offers so much more as well - get panorama glass fitted! No more need for window blocks, better security and a very clean look for your Landy!!
http://www.vehicleglazingspecialists.com Dave is a great guy and will sort you out, has done two of my cars so far!
James
Post #603340 20th Feb 2017 5:43pm
Swac3
That's not going to help keep your windscreen attached to the bulkhead tho James 3 Landrovers
Post #603342 20th Feb 2017 5:55pm
Bristol 90XS
Thats a very good point - when i read window blocks I assumed meant the ones on the sliding glass that corrode so easily!!
Must read more detail next time!!
James
Post #603344 20th Feb 2017 5:58pm
LR90XS2011
standard ones wiped over with ACF50 now and again are like new on mine after 5 years DEFENDER 90 TDCI XS,
Post #603365 20th Feb 2017 7:56pm
MR_JAMES
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
I sanded mine down and repainted myself with a spray can and lacquer. Look gorgeous! 1953 80"
1987 mini city e
2011 90"
Post #603443 20th Feb 2017 11:01pm
Balvaig
Thanks for your help and advice. Will probably order up a pair of Landrover blocks and paint to match. The left over paint will come in for stone chips etc. Time will tell how good my paint skills are Laughing
Post #603527 21st Feb 2017 10:15am
