![]() | Home > Technical > Rooftent and Anti Roll Bars |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10387 ![]() ![]() |
Hey. Any increased weight up top will have an effect on handling. Though favourable to have anti roll bars, they do restrict off road ability.
I'm sure Barouds are the best and lighter than most, just adjust your driving style accordingly and all should be good. Congrats on the Baroud, it would be my choice of rtt. ![]() |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7932 ![]() ![]() ![]() |
I guess it depends on the extent of off roading you do? I certainly wouldn't be without the standard ARB's we have on our 110 SW but then we 95% on road.
I'd speak to Ian at IRB Developments or Alive for advice ![]() MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
AlpsLandy Member Since: 11 Jan 2012 Location: Alps Posts: 116 ![]() ![]() |
Thanks GREENI. I will see how it goes then - I'm a definite 'plodder' anyway so hopefully won't need anything. Really looking forward to getting the tent on top. Had a close up look at a few and happy with the choice
![]() 2006 Discovery 3 HSE |
Hi James - thanks. I will certainly look into it if I have any problems or alarms. Only really use the 90 when I'm in slow mode so will see how it goes. 2011 Defender 90 SW
You might well have anti roll bars fitted, they seem to be one of the things that were fitted slightly at random.
My poverty spec 2011 Defender has them. |
agentmulder Member Since: 16 Apr 2016 Location: Outer Space Posts: 1324 ![]() ![]() |
FWIW, I noticed a difference in handling after the following changes:
- Removing ARB - Reinstalling ARB - Installing roof tent (with ARB fitted) This is on a 110. Given the slightly more unsettling differences felt I wouldn't opt for the (untested) tent and non-ARB option. I think it's a case that you'll be fine ... until you aren't? Solved the bowel problem, working on the consonants... |
Ah ok guys - thanks. I'm working away for another week so can't go check underneath to see if they are fitted...
If I do need them then, do I just buy a kit from paddocks or similar which has all the fittings and bushes etc for roughly £160, or do I not need all those bits if the chassis fittings are in place? Sorry for not having a clue ![]() Thanks for your advice. Ignore this question as I've found a thread with all the info ![]() 2006 Discovery 3 HSE |
Back home and had a look underneath to find ARB are fitted
![]() Now get that tent up there! Thanks for the replies ![]() 2006 Discovery 3 HSE |
