![]() | Home > Technical > Thermotop E no fuel |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2362 ![]() ![]() ![]() |
Broken pump ?
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 ![]() ![]() ![]() |
Unplug the pump and Jury rig a lightbulb to the connections.
If it flashes when you try and fire it up the pump is dead, if it doesn't then there may be a break in the cable or a fault with the controller. is where I would start, I'm by no means an electrical expert but it may save hours of stripping and buying parts speculatively. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter ![]() |
boode Member Since: 11 Apr 2012 Location: Devon Posts: 436 ![]() ![]() ![]() |
Thanks Shaggydog
I did not install the heater myself Is the pump located on top of the fuel tank ? That is where the clicking noise use to come from So do I need to drop the tank for access ? |
I'm afraid I couldn't say without looking.
I put mine in the rear wheel arch as the pickup for these pumps isn't that great so it will be close to the tank somewhere. Failing that, where did you get it installed? Give them a ring they may be able to diagnose it or take a look ![]() Self confessed mileage hunter ![]() |
Found the pump and tested the wires with a volt meter
The earth earths fine Volt meter reads a constant 8.5 when turned on I thing something has gone wrong - so a trip to the garage |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1681 ![]() ![]() ![]() |
I don't know the Thermotops, but the Eberspachers are very voltage sensitive, check your battery.
Andrew james Member Since: 02 Jan 2013 Location: Awliscombe Posts: 88 ![]() ![]() ![]() |
There may be a blockage in the fuel line, after the pump or as it enters the heater. It will not pump against a pressure hence not getting the clicking sound. If you can disconnect the fuel line after the pump and try starting the heater you can see then if it's the pump or is a blockage, as the pump will click again.
Thanks Andrew - I eventually found some time and disconnected the fuel line after the pump and the pump worked fine.
I then disconnected the line as it enters the heater block and then blew out the line with an air hose. Re connected everything and webasto now working perfectly - just in time for summer |
