Home > Technical > are early TD5 and 300 TDI bulkheads identical.
rodspink
Hi folks just wondering if an early TD5 bulkhead is the same as a 300 tdi. Certainly the dash layout seems to be the same.
Thanks
Rod
Post #602185 16th Feb 2017 8:03am
jst
If not identical they are certainly interchangeable Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #602186 16th Feb 2017 8:06am
On the under bonnet side some of the brackets are different, as the Tdi uses a different header tank to the Td5 (Td5 sits on 3 legs and mounts onto the bulkhead, whereas the Tdi is on the front corner of the wing)
Plus the clips for the front wing wiring loom plugs (although it may only be late Td5 that had these on plugs, I think early Td5 the wing looms were all part of the main dash harness?) and a few studs for earth joints and for mounting other loom fixings onto.
But as JST says, pretty much similar and certainly interchangeable.
Post #602188 16th Feb 2017 8:35am
rodspink
Excellent. Thanks.
This means I can extend my search area for a new one.
Regards.
Rod
Post #602238 16th Feb 2017 1:42pm
Romadog
The 300tdi wiring loom goes through the bulkhead via a round hole above the fusebox, whereas the TD5 uses the two oval holes at dash level. SO a hole will need to be drilled into the Td5 bulkhead to do this.
http://forums.lr4x4.com/topic/38064-galvanised-bulkhead-pointers/
Post #602342 16th Feb 2017 7:46pm
walfy
As JST says, they are interchangeable. I had an 86 Defender 90. Started life as a 2 1/4 petrol, then 3.5 V8, 3.9V8 and finally I fitted a 200TDI. After that I went in for a major rebuild. Fitted a genuine TD5 bulkhead. The top rail of the dash is different, so I cut the old rail off the top of the old BH and bolted it to the TD5. Also the the tunnel is different but you can buy/bolt on the specific tunnel adaptor from your current BH. The wiring loom was long enough to fit through the newer holes, just need to buy the correct gromits. Also the heater matrix mounts differently, so you'll need to drill a few holes and buy a new style gasket.
If you have any questions, please shout out 110 D250 SE HT
110 USW SOLD
RRE HSE Dynamic Gone, wife killed it
VOLVO XC60 R Dynamic with some toys
Polaris RZR 900XP SOLD
Post #602402 16th Feb 2017 9:49pm
rodspink
Thats ace.
Thanks again folks.
Rod
Post #602585 17th Feb 2017 2:33pm
NickMc
I buy my bulkheads from Robert at Mosside Land Rovers, maybe worth asking Thumbs Up
https://m.facebook.com/mosside.rovers/?locale2=en_GB
Post #603223 20th Feb 2017 1:31am
rodspink
Cool.
Thanks for that. Iv added on facebook.
Cheers.
Post #603238 20th Feb 2017 7:38am
rodspink
Thanks all. Got a new one in ebay and its local. Problem sorted. Although it leads to some more questions. Will start a new thread I think. Lol.
Post #603276 20th Feb 2017 11:39am
