![]() | Home > Td5 > TD5 Power Clutch |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2239 ![]() ![]() ![]() |
Easiest and cheapest thing to do is fit this -
http://www.ebay.co.uk/itm/LAND-ROVER-DEFEN...Sw2XFUdJiP Takes about 30 mins of swearing and fitting and its done! Clutch is CONSIDERABLY lighter. |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5141 ![]() ![]() ![]() |
The spring replacement is a popular mod, but while it makes the clutch pedal lighter it does not really make that much difference, what Laurie needs is this A Red Booster clutch servo. Once fitted you can press the clutch pedal down with one finger. Red Booster makes a servo to fit all variants of a 90 110 and all Defenders/
http://www.redbooster.com/ ![]() Read some TD5 Red Booster Testimonials here http://www.redbooster.com/photos ![]() http://www.youtube.com/user/conwy1 |
True! But worth trying something for £22.50 and it may be fine before dropping £500+ if not needed!
